Old 08-22-2009, 05:35 AM
Ru_C Ru_C is offline
Default Does Elastic-time affect the sound/tone, even on sections where it is unused?
Am still experimenting with E.A, as i only ungraded to HD7.4 recently.
A question...If I have (for instance) a bass track, & I only use E.A to alter the timing of one note...will the rest of the rest of the track suffer sonically in any way?
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 08-22-2009, 07:39 AM
JMDNYC JMDNYC is offline
Default Re: Does Elastic-time affect the sound/tone, even on sections where it is unused?
I'm not an expert at this, so this is just my guess -- I think of Elastic Audio as like fades. After it analyses the track, if you make a change to one note then it renders that change as a fade would be rendered. That's why if you move a project to a different drive it can re-render the elastic audio, just as it can re-render fades.
On sections that are affected, stretched or pitched, then yes you can hear a difference based on the algorithm used, but the untouched sections remain untouched.
Is this right?
Old 08-22-2009, 07:45 AM
studiojimi's Avatar
studiojimi studiojimi is offline
hate to give a question to your question cuzi hate hate.
what do your ears tell you?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 08-22-2009, 07:55 AM
haha, yes i know...but i've only been messing with it in earnest for a week, & am a bit afraid to start 'E.A'ing all over the place on a commercial release, only to decide it's a bad idea a month down the line..
What do *your* ears tell you, I value *your* opinion & anyone elses if they'll give it?
Old 08-22-2009, 08:05 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Nope...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-22-2009, 08:17 AM
Kenny Gioia Kenny Gioia is offline
If done right, the other audio should be unaffected.
To test it, separate your region right after the section you've fixed and see if it has an EA icon on it. If it does, then it's being stretched too.
Good luck.
Old 08-22-2009, 09:48 AM
Giles Reaves Giles Reaves is offline
I've noticed a particular scenario in polyphonic mode on acoustic guitar (one of EA's torture tests) where analysis markers can cause an audio glitch (ones without warp markers). Deleting these "unused" analysis markers clears the glitch. it's not consistent (the initial glitch), but it DOES qualify for your topic.
Giles Reaves
Somewhere Between Tennessee & Utah...
Old 08-22-2009, 10:25 AM
formfunction formfunction is offline
That is good to know. Thanks Kenny, ff
Old 08-22-2009, 11:37 AM
elicious elicious is offline
yes it does, sometimes on sustains (vox, gtrs),,,
opening elastic properties and setting sensitivity to zero can help this.
b.o.l.
e
ihatetyping
Elastic Time is EXCELLENT.. how about Elastic Pitch.. bobo mark Pro Tools TDM Systems (Mac) 9 08-29-2008 10:41 AM
elastic audio artifacts on unstretched sections of a region axisrecording Pro Tools TDM Systems (Mac) 1 02-26-2008 07:05 AM
Copy Paste to affect also unused playlists? wonderfall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-29-2005 10:07 AM
Exporting project sections only real time? kwk13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-11-2003 12:47 PM
Will bounce to disk really affect your sound? leon777 Pro Tools TDM Systems (Mac) 28 10-02-2002 04:30 PM
