Launching Session Causes Duplicated Audio Files
I've searched around through the forum and was unable to find anything related to this. I apologize if this topic was covered elsewhere.
Every time I launch my session every audio file in the clip list is greyed out and a task begins called "Processing Audio". It goes through every file in the list and creates a duplicate file "Filename.1.wav". (adding ".1" to the file) I've even tried starting from scratch with only a single playlist. Import 1 audio file. Save, Close. Re-open session and it duplicates the file in the same location. Which by the way is under Audio in the session folder. Also..Session and audio files have matching bit-depth. I'm obviously missing something here... Any help on this silly issue would be greatly appreciated. |
Re: Launching Session Causes Duplicated Audio Files
Hi !
Where do you have the disk allocation pointing too ?
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Each track is set to the Root Folder of the ProTools Session file
Custom Allocation Options is Unchecked Create subfolders....is Greyed out and Checked Use round robin allocation is Unchecked |
Importing audio files for remix - convert or set session to match source audio? | LSW | Tips & Tricks | 22 | 09-09-2014 09:28 PM |
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
usaved PT session saving unsaved audio files to audio files folder | mermermer | Pro Tools HDX & HD Native Systems (Mac) | 1 | 07-18-2012 11:50 AM |
files from Mac to PC get duplicated with ._ | crizdee | Pro Tools TDM Systems (Mac) | 2 | 12-07-2008 05:57 AM |
Saving session files/Trashing audio files | digigirly | Tips & Tricks | 2 | 02-08-2002 09:55 AM |
