Old 01-06-2020, 01:42 PM
jglunt2112 jglunt2112 is offline
Default Backwards
I have a situation that is backwards from anything else I've ever heard of. I'm using Pro Tools 12.5 on a Windows 10 computer. I've used this same system with minor upgrades for about 4 years. I took most of December off in the studio, and now that I'm back, I discover that I have audio in Pro Tools but nowhere else. No itunes, no Windows Media Player, no YouTube. Not a peep out of anything except Pro Tools. All of my audio runs through my USB audio interface (a Behringer U-Phoria UMC 1820), so if I hear Pro Tools, I should hear everything, but I don't. Though I took December off in the studio, I did drop in to check out a few things, grab an instrument for a gig, that kind of stuff, but as near as I remember, I didn't do anything to the computer except to maybe turn it on to listen to something on itunes while I did some other work. It worked right then, but not now, Any ideas? (A current Sandra Report is attached). Thanks.
Jim
SiSoftware Sandra
ID
Host Name : TheTreeRecordingStudio
Workgroup : WORKGROUP
Computer
Model : GigaByte
Serial Number : To be fille***********
Chassis : GigaByte Desktop
Mainboard : GigaByte B75M-D3H
BIOS : AMI (OEM) F13g 11/21/2012
Intel vPro : 8.1.2.1318
Total Memory : 16GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (4C 8T 3.79GHz, 3.8GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : Gigabyte Core3 (Ivy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.33GHz 128-bit
Memory Module(s)
Memory Module : G.Skill F3-1600C9-8GXM 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : Hewlett Packard HP LV2311
(1920x1080, 23.1")
(1920x1080, 23.1")
Video Adapter : NVIDIA GeForce GT 610 (48SP SM5.5 1.62GHz/1.15GHz 40% OC, 1GB 998MHz, PCIe 2.0 x16)
Graphics Processor
D3D 11 : NVIDIA GeForce GT 610 (48SP 810MHz/1.15GHz, 1GB 998MHz)
OpenGL : GeForce GT 610/PCIe/SSE2 (1GB)
Storage Devices
WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) : 466GB (G:)
Crucial CT500MX500SSD1 (500.1GB, SATA300/600, 2.5", SSD, OPAL, SED) : 466GB (C:) (D:) (F:)
Flash Disk (4GB, USB2/NVMe) : 4GB (J:)
TSSTcorp CDDVDW SH-224BB (416.5MB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 397MB (E:)
Logical Storage Devices
Onboard Data (G:) : 466GB (NTFS, 4kB) @ WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache)
System (F:) : 230MB (NTFS, 4kB) @ Crucial CT500MX500SSD1 (500.1GB, SATA300/600, 2.5", SSD, OPAL, SED)
WAVES USB (J:) : 2GB (FAT, 32kB) @ Flash Disk (4GB, USB2/NVMe)
Windows (C:) : 464GB (NTFS, 4kB) @ Crucial CT500MX500SSD1 (500.1GB, SATA300/600, 2.5", SSD, OPAL, SED)
Hard Disk (D:) : 857MB (NTFS, 4kB) @ Crucial CT500MX500SSD1 (500.1GB, SATA300/600, 2.5", SSD, OPAL, SED)
Audio CD (E:) : N/A (CDFS, 2kB, Read-Only) @ TSSTcorp CDDVDW SH-224BB (416.5MB, SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller #1 : Gigabyte Panther Point LPC Controller
LPC Legacy Controller #1 : ITE IT8728F
Audio Device : Gigabyte Panther Point High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : MSI HDMI Audio stub
Audio Codec : nVidia 001C
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Gigabyte Panther Point 4 port SATA IDE Controller
Disk Controller : Gigabyte Panther Point 2 port SATA IDE Controller
USB Controller #1 : Gigabyte Panther Point USB xHCI Host Controller
USB Controller #2 : Gigabyte Panther Point USB Enhanced Host Controller #2
USB Controller #3 : Gigabyte Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller #1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft Software Printer Driver (300x300, Colour)
Printer : Microsoft Print To PDF (600x600, Colour)
Peripherals
Media Player : USB Flash Disk (1.87GB)
Network Services
Network Adapter : Realtek PCIe GbE Family Controller (Ethernet, 100Mbps)
Wireless Adapter : Realtek 8812AU Wireless LAN 802.11ac USB NIC
Operating System
Windows System : Microsoft Windows 10 Personal 10.0.18363
Platform Compliance : x64
Old 01-06-2020, 02:30 PM
Default Re: Backwards
Its almost always best on a Windows-based setup to NOT let Windows use the audio interface for playback. Instead, go to Sound Properties and set Windows to use the on-board audio as its "Default Playback Device". That way, Pro Tools has total control over the interface for setting sample rate. There are many ways to get non-PT audio out thru your speakers(but usually, getting Pro Tools working is the priority). Once Pro Tools is working properly, here are a few options for all other audio:
1-use a monitor/source selector(like Presonus Central Station, Audient NERO, Mackie Big Knob, etc) and feed SPDIF or mini-TRS from the computer's on-board audio.
2-route both the interface outputs(for Pro Tools) and the computer's sound card outputs thru a baby mixer(as available from Behringer, Alto, Alesis, etc)
Old 01-14-2020, 01:54 PM
This worked like a charm. I used a JBL M-patch Active to route the signals and it's much better. Thank you!
Backwards Compatibility kloqwyse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-28-2010 05:11 PM
Backwards compatible nickster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-25-2006 09:09 AM
backwards EQ?? garret Post - Surround - Video 13 11-18-2005 12:37 AM
ProTools with OSX-- Are we going backwards?? Mt.Everest Pro Tools TDM Systems (Mac) 174 04-02-2005 02:58 PM
backwards tracks jas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 03-02-2005 11:05 AM
