Mbox2 Mini causing MacBook Pro to hang on shutdown...
I got my MacBook Pro last week, and at the same time bought Pro Tools LE 8.
My mac starting hanging on shutdown and I had to restart by holding the power button, I didn't know what the problem was and have been on the phone to Apple a few times about the issue. I've reset the PRAM etc etc and done other things recommended by Apple, Apple haven't been able to pinpoint the issue with their tests but have said it is a software issue, they said the next step will be to do an 'archive and restore', I have also bought Snow Leopard but as yet haven't installed it due to some of the glitches people are finding with Pro Tools. Anyway, it just happened again and I read the system report about the crash and I noticed that 'Mbox2' kept coming up mixed in with all the coding and numbers... so I'm guessing this is what is causing it. I also use the Mbox as my sound card just for ease of use so that I don't have to keep changing audio cables into my Mac. Has anybody else had any issues similar to this or now how I can fix it, I am going to tell Apple even though they will probably just say uninstall it. |
Re: Mbox2 Mini causing MacBook Pro to hang on shutdown...
If not, download and install PT8 cs3 and PT 8.0.1. I haven't had any issues since, but if you still have leopard 10.5, wait until SL is officially compatible.
Jim Carroll |
i have pt8.01 and osx 10.5 not snow leopard,im not installing 10.6 yet. The problem isnt pro tools,its the mac that crashes when i try to shut it down (the mac that is). Bt when it comes bk on,it says the kernal panic is due to the mbox
Are you closing Pro tools before shutting down? That might not be a bad idea. Do you still have the Kernel Panic if you unplug the Mini before shutting down?
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
bump anybody?
But have you tried unplugging the MBox before you shut it down?
This seems to have been a long running problem for many users. I don't have this problem but here is a link to a thread that talks about this.
http://duc.digidesign.com/showthread...t=kernal+panic (I have not read it from beginning to end so I'm not sure if there is an answer in there or not). Perhaps it will provide some perspective on the issue.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Apparently cs3 addressed some kernel panics.
You must not unplug the Mbox 2 before shutting down the machine, toggling audio prefs doesn't help. A royal PIA.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
8.0.1 includes the fixes included in cs3, so the only reason you should get a kernel panic is if you unplug the Mbox 2 while the computer is on, as the Dougfather said.
Mini Grand causing shutdown | ericbenner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2011 04:49 AM |
MBox2 Mini on Mac causing problems | bearinpng | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-23-2010 07:59 AM |
MBox2 Core Audio Driver causing programs to hang | Chri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-29-2007 07:11 AM |
SHUTDOWN HANG | VUZZ13 | Digidesign Hardware & Software | 3 | 08-31-2001 08:57 AM |
Hang on Windows shutdown screen in Win98SE | cs759 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-07-2000 08:09 AM |
