Session pitch going down when i move from digi001 to m-audio
Hi.
The trouble it's fooling me it's this one: I record my sessions on the sutudio. There we have a desktop PC with digi001 (pt 6.4). The digi is connected with an OCTOPRE LE, thru adat, using the AD/DA expansion of the focustrite pre. I guess that's the center of the question, but i still don't know how to solve it. Then i take the sessions and open it at home, in a desktop PC with a m-audio audiophile 192 (pci), and protools m-powered 8. Everything it's right, excepting the whole pitch of the session is bit down, even the tempo remains the same! Does someone have some light on the matter? thanks a lot in advance |
Re: Session pitch going down when i move from digi001 to m-audio
First of all, I am not quite sure about the 001 and 6.9? The last release for the 001 was 6.4.
You are experiencing a clock issue. Check that the sample rate is the same on both sessions. If you go from 48k to 44.1k your pitch will be lowered, although so will the tempo.
Sign up for all things....AWESOME! Kris May the music move you |
Definitely go back to PT6.4 with CS6 and CS9 for your 001, and run XP32 with SP2 or SP3 and no IE8.
The problem is that the session sample rate and the sample rate of the Octopre were different.
In Pro Tools M-Powered, create a new session at 48k and choose to import all tracks from the session you were working with and uncheck the box for sample rate conversion. That will import all of the audio files in at the correct sample rate. |
Thanks for the answers. And sorry, it is of course 6.4 in the 001.
Yes, the sample rate seems to be center, but i don't see how to solve it. Maybe this idea of importing from the session without resampling could be. Let me check it. |
Well, here i have a step, but i guess i would have to solve it from the root to have a good work method. |
Onya DTS!
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
Are your tracks set to Ticks or Samples? They should be set to Samples...if they're set to Ticks, that could cause a problem like this... |
http://duc.digidesign.com/showthread.php?t=250000 _
Faders won't move and no audio, yet still controls session? | spall | ProControl, Control|24, Command|8 | 2 | 06-24-2011 09:57 PM |
PT9 Saves a Session Copy in my Mac HD after I move a Session | BJosephs | macOS | 4 | 04-06-2011 01:26 AM |
Old Session in PT8... No Elastic Audio/Pitch? | M2E | Pro Tools TDM Systems (Mac) | 3 | 05-16-2009 10:04 PM |
Time to move the Digi001, tips, what to do? | nuke | Tips & Tricks | 2 | 02-24-2007 03:19 AM |
where's my pitch plugin? digi001 OSX 6.4 | rexdime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-19-2006 05:54 AM |
