Re: assertion errors how to fix
Removing them is usually enough! although trashing the prefs will make sure the cache is empty before rebooting pro tools. The last few things you changed!! sounds a bit of a coincidence so i would concentrate on them. Ram? can you remove half the ram and try? then switch ram around to the half you removed etc! Chris
Here is another "crash" item:
Exception Type: EXC_BREAKPOINT (SIGABRT) Exception Codes: 0x0000000000000001, 0x0000000000000000 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Application Specific Information: abort() called Thread 0 Crashed: Dispatch queue: com.apple.main-thread 0 libSystem.B.dylib 0x91d1dc5a __kill + 10 1 libSystem.B.dylib 0x91d1dc4c kill$UNIX2003 + 32 2 libSystem.B.dylib 0x91db05a5 raise + 26 3 libSystem.B.dylib 0x91dc66e4 abort + 93 4 libstdc++.6.dylib 0x9554cfda __gnu_cxx::__verbose_terminate_handler() + 433 5 libstdc++.6.dylib 0x9554b17a __cxxabiv1::__terminate(void (*)()) + 10 6 libstdc++.6.dylib 0x9554b1ba __cxxabiv1::__unexpected(void (*)()) + 0 7 libstdc++.6.dylib 0x9554b1ca __cxxabiv1::__unexpected(void (*)()) + 16 8 libstdc++.6.dylib 0x9554ac59 __cxa_call_unexpected + 67 9 ...design.framework.FileFormat 0x00a31ac5 BDM_Globals::Release() + 101 10 ...gidesign.framework.ProTools 0x152aefd2 MFortressHWBPEntryPoint_exit_mfort6317_ + 27317320 11 ...gidesign.framework.ProTools 0x152b0749 LaunchProTools + 1305 12 com.digidesign.ProTools 0x0000f317 0x1000 + 58135 13 com.digidesign.ProTools 0x0001041a 0x1000 + 62490 14 com.digidesign.ProTools 0x0000f09d 0x1000 + 57501 |
David Hughes Sound Designer shineonstudio.com Mac Pro 2 x 2.4GHz Quad Core Intel Xeon, 14GB 1066 MHz DDR3, Avid OMNI HD (Rev A), Digidesign 192, Pro Tools HD v. 10.3.9 |
assertion errors that aren't going away | dobatron81 | Pro Tools TDM Systems (Mac) | 1 | 03-20-2009 06:09 PM |
Assertion errors? | DarthFader777 | Post - Surround - Video | 10 | 02-17-2009 10:18 AM |
neo assertion errors help | rboos4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 07-29-2008 09:02 AM |
Assertion Errors? | Chaka015 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-26-2007 08:51 AM |
Anyone else get Assertion Errors? | beggehorn | Pro Tools TDM Systems (Win) | 4 | 12-01-2003 11:53 PM |
