Old 12-03-2010, 03:45 AM
-JK- -JK- is offline
Default Strange CoreAudio issue - right channel information getting into left channel
I'm using a 003 Rack + with Pro Tools 9 and I am experiencing a strange issue since today. I was playing a test track to set up my monitors and noticed that there was a severe bleed from the right channel to the left one when the waveform showed no signal on the left channel at all.
I double checked that with my Rosetta 800 which shows activity on the left channel when playing the right channel stereo file, so a cabling issue is out of the question. The Rosetta can't be the issue also because the bleed occurs on the headphones output as well. I tracked the problem down to the CoreAudio Manager/driver as the same file plays without problems in Pro Tools 9.
Any idea how I could fix that? A firmware reset didn't help.
Regards, JK
Old 12-20-2010, 10:10 PM
samwise samwise is offline
Default Re: Strange CoreAudio issue - right channel information getting into left channel
It's how iTunes talks to the Coreaudio driver, it's messed up. Listen to it through quicktime or VLC, you'll see that they work fine...
Old 12-29-2010, 12:06 AM
Hi!
Thanks for the hint, didn't have time to test it though as I ditched my 003 Rack in favor of a Studio Konnekt 48. I'm sure that's good to know for a few other guys out there!
Regards, JK
Old 12-30-2010, 08:33 AM
Park Seward's Avatar
Park Seward Park Seward is offline
It isn't software or others would have that problem.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-09-2011, 04:26 AM
Sonic Nomad Sonic Nomad is offline
Originally Posted by -JK- View Post
Hi!
Regards, JK
+1 on the Konnekt 48
Better convertors and a cool product now that TC have got the drivers right.
There used to be an issue with Digi interfaces having inverted polarity in the core audio drivers. Not sure if this has been addressed.
Old 01-10-2011, 08:42 AM
Yeah, it's a good interface with an even better bang for the buck, but the dying-input-potentiometer-problem is kind of freaking me out. I got a unit with two of four defect gain pots and don't really look forward to trying this thing out live as a matter of fact. Otherwise it has great features for half of the price of it's closest competitor, the UFX (which doesn't have a remote included and doesn't have dedicated phone output knobs either).
[IMG] code is Off
002, left channel only! Jay002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-16-2011 12:34 PM
Stereo in only on left channel badbiker ICON & C|24 7 04-15-2011 12:28 AM
How to separate left from right channel? supadisco Tips & Tricks 7 11-11-2002 02:16 PM
rewriting Midi Channel Information Steve Moore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 09-30-2002 12:05 AM
fix for left channel Jeff Hodges ProControl, Control|24, Command|8 8 05-05-2002 04:51 AM
