M-Audio Keyboards BUG ! PT 11
Hey Folks,
Did anyone encountered the following when enabling his m-audio midi controller in Peripherals in Pro Tools 11: Blue labels on all tracks auto record enable for any instrument track whenever is selected error msgs that unable to communicate with the midi controller noise distortion when running sample rates of 96khz Please advise .... Best
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.3 Pro Tools 2024.3 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
Re: M-Audio Keyboards BUG ! PT 11
My M-Audio Axiom is constantly dropping out. I had to reinstall the drivers
on each occasion. |
but what drivers are there for mountain lion ?? i dont think there is any .... if so .. link me
Say the bug will always remain .. "sigh"
What is the best working midi controller with Pro Tools 11 ?? Anyone ?
uhmm .... thanks
As someone who's been hovering around the M-Audio AIR Axiom keyboard controllers -- which in theory should be perfect for controlling PT11 -- I have to say communication from the company about problems like these has been sorely lacking ... to the point of being a complete turn-off.
There are no serious reviews of any of the larger AIR Axioms, and apparently no sales to speak of at the major retailers despite the keyboards being out for a few months. I don't know everything, but from the outside looking in, the entire AIR Axiom line appears to be a botched release. Of course had the company deigned to give us even a few words explaining the circumstances from its viewpoint, people wouldn't post questioning the company's entire strategy. |
Bottom line ... Which midi controller actually works ??! With pt11
We use Akai Synthstation 49 with Pro Tools and it works like a charm here on OSX 10.8.3 http://www.akaipro.com/synthstation49/?tt=5 I know some midi controllers doesn't have the correct installers yet for PT11 but our Akai worked via USB3 port on MBPr 2013 perfectly. Best Regards Chris
One question ... how can i setup the midi controller to work in pro tools (running Mountain Lion) without the need to add it in the peripherals menu ... (if there is a way ..)
Cheers
On previous versions, I tried the Hyper control functionality to work as advertised. I just didn't use it that much due to a physical studio set up issue. On 11, I have had a bit of functionality of the hyper control going, but I switched it off pretty much right away. As far as MIDI on 11 goes, I had to create an Instrument Track and an Audio track, sond the output if instrument via bus to input of audio. Then I have to "arm" the instrument track. (Record enable) In no case can I simply arm the audio track, set focus on the instrument track and play with results. If I want the two track set-up so that I can record audio, I have to record enable both the instrument track and the audio track. Yes, that means I also have to record MIDI at the same time. If I'm just practicing, this doesn't matter, obviously. If I want to record, it's a bit of a pain. The audio track is also the first to show up in the edit-undo menu item. I gotta get rid of it (The MIDI) the hard way, so to speak. So gain, in 11 for me, some success. Method #1: Arm Instrument track alone with output going to main out = volume. Method #2: Arm Inst track, arm audio track, ouput of inst bussed to audio, record enable both = volume. I do have an Alesis down stairs that I'm going to try out to see if that helps for my issue with pt 10.3.6. I'll try on 11 just for giggles to see if it performs the same way as the Axiom. |
New M-Audio Axiom A.I.R. Midi keyboards | nst7 | Virtual Instruments | 4 | 07-15-2012 01:00 PM |
who has a good reason why m-audio KEYBOARDS | dubhausdisco1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 12-16-2006 06:10 PM |
Keyboards in the mix | Palnatoke | Tips & Tricks | 0 | 11-12-2005 12:15 AM |
USB Keyboards | danger | Pro Tools TDM Systems (Mac) | 4 | 01-30-2005 04:09 PM |
E-mu MK-6 or other E-mu Keyboards | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-05-2003 01:38 PM |
