MIDI quantizing dilemma
Hello,
I'm trying to figure out how to quantize the ends of my notes (getting them to touch each other without overlapping). Recording MIDI is easy enough, along with quantizing the beginnings of the notes to snap to grid. In the event operations window I'm not seeing anything in the quantize section that would accomplish this, it's just to snap to the nearest 1/16th, 1/32nd and so on. No options to stretch the midi notes so they touch each other like sustaining until the exact point of the next note strike, not overlapping each other. The only other place I would guess would be under the "change duration" section and then the "legato" section, unfortunately this doesn't stretch the notes proportionally, it picks what seems to be a random note and stretches each note exactly the same, thereby leaving gaps between the rest of the notes. It doesn't seem to matter what I set the overlap to, and oddly enough if I try to do it this way, it overlaps certain notes but not others. I've seen this done in other DAWs, Propellerhead Reason is really easy. Thanks for your help. Josh |
Re: MIDI quantizing dilemma
Select all the notes in the midi editor go to Event Operations in the Event menu then Change Duration then choose Legato and either gap or overlap depending on what you want to achieve then set the value you want as a gap or overlap then hit apply. That should do the trick. Oh and make sure you haven't got any Real Time Properties on the track which will over ride this.
ASUS P5k, Win 7, RME Multiface Macpro, 10.8.3, Digi 003 Profire 2626 PT 10.3.6 |
MIDI Quantizing Help | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-23-2008 06:57 AM |
Midi Quantizing!?? | Edifice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-03-2008 05:42 AM |
Need Help Quantizing Midi on PT 7.1!!! | dlinnov8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-18-2006 09:15 PM |
Midi Quantizing in 6.4 le | Cyco | MIDI | 6 | 08-30-2004 07:04 PM |
Midi Quantizing with PT 5 | Pro Tools TDM Systems (Mac) | 1 | 11-30-1999 11:14 AM |
