Old 02-17-2004, 11:12 AM
SurroundNewbie SurroundNewbie is offline
Default 192 I/O to Dsm71 Tdif cable question
Hi.
To connect a 192 I/O to a Tascam DSM7.1, is all that is needed a standard DB25 TDIF Dubbing/Transfer cable?
Digi's Tdif cable is $150. Tascam's PW88DM is $15.The DSM will live in the same rack as the 192, so the run is very short. Is there any reason to buy Digi?
TIA,
SN
Old 02-17-2004, 05:24 PM
schmidy@bitter_zen schmidy@bitter_zen is offline
Default Re: 192 I/O to Dsm71 Tdif cable question
A standard TDIF cable into Slot 1 (Console) is all you need.
Old 02-17-2004, 06:54 PM
Richard Fairbanks Richard Fairbanks is offline
Any standard TDIF cable is fine, but not a straight computer cable! You can make a down and dirty TDIF cable quickly. Get a 25 conductor flat ribbon cable and two male D25 ribbon connectors (Radio Shack will do). Put a connector on each end but flip one of the connectors so that it is "upside down". Whereas a regular cable would connect pin 1 to pin 1, 2 to 2 and so on, a TDIF cable connects pin 1 to pin 13, pin 14 to pin 25, and so on. This makes sense when you look at the numbering of the connector pins. I have used one of these for years. I say it is down and dirty because it is not shielded and so spews digital noise everywhere. This is often no problem whatsoever, but I would not want to use it in a permanent installation for that reason. It will not take much physical abuse but a short run in a semi-permanent rack would be fine.
Call me by my real name, "Postman"
Old 02-18-2004, 09:43 AM
Thanks!
HTML code is On
TDIF to MADI Question Scott Fahy VENUE Live Sound Systems 6 01-01-2011 09:30 AM
TDIF question? ctyelvis Pro Tools TDM Systems (Mac) 8 11-30-2009 07:15 AM
TDIF SYNC I/O clock question jimlongo Post - Surround - Video 0 01-25-2005 02:27 PM
Digi 001 I/O Cable Question (need longer cable) M@tt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-16-2001 01:47 PM
Digi 001 I/O Cable Question (need longer cable) M@tt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-15-2001 10:08 PM
