MMC sync question
trying to syn 2 PT LE via MMC, I'm able to control the slave machine to play and stop following the Master, but the master machine doesn't play when it was 'transport = mmc"
is there any method to make both play together? Thanks a lot! __________________ King Kong
King Kong |
Re: MMC sync question
Until I went HD, I would sync 2 LE rigs together when I needed more than 18 inputs. I believe the way you are doing it is the only way. The slave's transport is online waiting for MMC from the master. I also sync'd the clocks.
Just saw you posted in the mac forum too, and got an answer there.
https://www.thirdeyerecording.com/ |
I'm using them for a live gig, wanna sync the main and backup program machine to run together,
so i also want to know, If the master machine hang up, will the slave keep running ( assume that the master didn't generate a 'stop' signal)?
King Kong |
Sorry KK, I don't have an answer for you. Maybe you could slave both systems to a 3rd sync device.
Regarding if the slave will stop if the master does, perhaps you could setup the system and experiment with it to see if it does what you'd want.
ok . I will try it out. thanks!
King Kong |
Sync Question | SKYHIENTERTAIN | Post - Surround - Video | 2 | 07-28-2009 03:41 PM |
MMC sync question | King Kong | Pro Tools TDM Systems (Mac) | 4 | 07-28-2009 02:00 AM |
MMC sync question | King Kong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-26-2009 07:25 AM |
MMC sync question | King Kong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-26-2009 04:36 AM |
Sync Question | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-04-2003 06:40 AM |
