#31
Re: Happy travelers?: PT11 & Softube Console 1
Console 1 sees each channel individually as does PT. If you disable an eq on one channel with C1, it does not affect the other channels. So each channel is individual on either system. Pro tools for automating only sees what you tell it to. Trying to disable 1 parameter of plugin automation is a hassle regardless of what plugin you are using. If Eq was the only thing you had automated, you could just turn the automation off and on per each channel, which means you can use short cuts and do them all quickly.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#32
#33
Interesting.
Do you have any of the parameters turned on inside the plugin??
#34
So from what I can gather-- this is some sort of bug and/or peculiarity with the (mono/stereo) version of the plugin. Both the mono and stereo versions of the plugin show the parameters like normal. However, if I insert the (mono/stereo) version on a mono audio track it doesn't display the discrete parameters for enable/disable.
Now as far as I can see, inserting the (mono/stereo) version is the only way to pan a mono track with the console one pan knob... Henrik, are you out there? Any thoughts on this? |
#35
As far as not having any parameters available on that track, that would be a bug!
#36
Yeah... I wonder if anyone could verify whether or not they get the same thing. It occurs to me that I'm still on PT11.2, so there's a chance that maybe this been resolved in the update? Although it seems unlikely that its a Pro Tools thing causing the bug...
I've got a support request into Softube-- so, we'll see what they think. Last edited by crandallwarren; 01-29-2015 at 07:28 AM. |
#37
Softube Console 1?
Any more folks using or still using Softube Console 1?
I saw it yesterday in person for the first time. My nephew and his homie came over to mix a song they had. Their laptop spdif out. First they pulled out this Push controller and fixed some stuff up in Ableton. Bounced and imported the new tracks into a 40+ plus Logic session, sat on the couch, and pulled out the softube console. They were zipping around this Console thing like they were on a real console. Dedicated knobs much better than any controller baring an Icon D-Control. They also used the softube CL1B with the console as well. Does the console 1 work with all softube plugins? Is the 4000 the only console they have? Last edited by Wall2Wall; 11-08-2015 at 01:14 PM. |
#38
Re: Softube Console 1?
#39
Hello guys,
I'm coming back to this old thread because Softtube has really good deals right now... My question about the track numbers and organisation: my template looks f.ex. like this: 3 kick tracks 1 Kick Sub Group fader 2 Snares 1 Snare Sub Group Fader etc... when I put Console one on the Kick Group Fader will it have the "number 1" in console 1 when I put Console one on the Snare Group Fader will it have the "number 2" in console 1 or will the Kick Group fader will be on "number 4" because it's the 4th track in PT. When I put the plugin only on AUX groups and I move tracks and Auxes in the PT main window will the console 1 assignements keep my numbers/channels?
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32 Last edited by danyg; 04-28-2016 at 12:18 AM. |
#40
The thing that really drove me nuts was the way you have to go about re-ordering tracks in Console 1, which is sort of like copying channels on digital console. You have to use a sequence of buttons to copy and paste-- you can't use a keyboard or mouse for this... What really broke it for me was when I got my artist mix. Using the two together is kind of impossible because neither one can follow the other. I just found that it was slowing me down and I was having to put a lot of energy into making everything work with Console 1. I think if you have a template that you always use and you can build Console 1 into that-- then it can be useful. Also, if you're doing stuff as if you were going to a tape machine, with minimal editing (vocal rides, plosives, lip smacks, etc...) Last edited by crandallwarren; 04-28-2016 at 07:01 AM. |
Not happy with PT11 - not working | 7thheaven | Pro Tools 11 | 2 | 12-28-2014 06:21 AM |
New Solid State Logic XL 9000 K-Series module for Softube Console 1 | denka | AAX Plug-ins | 7 | 11-19-2014 01:06 AM |
Monitoring PT11 HD Native with no console? | kirkbross | Pro Tools HDX & HD Native Systems (Mac) | 6 | 02-19-2014 11:47 PM |
64 bit AAX for Softube? | PatriotsBiker | AAX Plug-ins | 6 | 10-01-2013 12:24 PM |
Softube PT11 release after summer | Carl Lie | AAX Plug-ins | 9 | 06-26-2013 04:10 PM |
