Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 12 Discussion
Old 01-12-2018, 05:16 PM
Jason.Thomas84 Jason.Thomas84 is offline
Default Re: Pro tools won't play.
Yep got it. Was just curious. Thanks, I will give that a shot and see what happens.
Sent from my SM-G950U using Tapatalk
J
Win 10, 64 bit, 16gb Memory, Intel i7-7700k CPU, 4.2GHz
Pro Tools 12.8.3
Interface- Focusrite 18i8 2nd Gen
UAD-2 Satellite
Old 01-12-2018, 08:19 PM
So I just ran a 2 hour session after I isolated the Focusrite to Pro Tools only and defaulted the internal sound card for everything else and it worked flawlessly. Great tip.
J
Pro Tools 12.8.3
UAD-2 Satellite
Old 01-12-2018, 08:24 PM
Gillithekid Gillithekid is offline
When I launch pro tools version 12.8.2×106 , whether I open a recent session or create a new session when the edit window opens I press play in the transport window the play button lights up green and the stop button lights up blue immediately and stops the playback. No error messages pop up. Focusrite driver version 2.5.1. Playback device set to Focusrite line out. Recording device set to Focusrite line out.
Pro tools 12.8 subscription for education
Focusrite 2i2
HP PC windows 10
Old 01-12-2018, 08:29 PM
Where can I go to isolate Focusrite to pro tools only?
Focusrite 2i2
HP PC windows 10
Old 01-12-2018, 08:30 PM
Windows 10 HP 64 bit
Focusrite 2i2
HP PC windows 10
Old 01-12-2018, 08:35 PM
If you hover over the little speaker icon in the toolbar in the bottom right corner of the screen, you can see where system sounds are defaulting to. I selected that and switched it off of Focusrite and onto my internal sound card.
J
Pro Tools 12.8.3
UAD-2 Satellite
Old 01-12-2018, 09:37 PM
Windows 10 right click on the speaker icon for sound configuration, i made the change to recording devices to my sound card. In the recording device list It has the options to have the Focusrite in a disabled status , ready status , default device or default communication device. I chose to make the sound card the default recording device. Under sound card properties ( listen tab ) I checked the listen to this device box and selected the Focusrite as default playback device. In the advanced tab for sound card properties I checked the allow applications to take exclusive control of this device and the box to give exclusive mode applications priority. Is this incorrect settings?
Focusrite 2i2 1st gen
Pro tools
Focusrite 2i2
HP PC windows 10
Old 01-12-2018, 10:02 PM
Default Pro tools won't play.
Why are you doing all this?
For the third time now... do NOT select the Focusrite as the Windows Audio device, why do you keep telling us you have it selected and asking if that is OK?
It should not be selected *anywhere* for anything in the Windows Sound control panel (the thing you are getting to from the Speaker Icon).
Select your motherboard or internal PC sound card as that device, *NOT* the Focusrite.
Now select the Focusrite as the Playback Engine in Pro Tools. Setup>Playback Engine.
Pro Tools 11 won't play jp2ndtime Pro Tools 11 Discussion 3 08-23-2013 07:06 PM
Pro-Tools won't play Simsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-06-2010 03:24 PM
how to free resouces in pro tools ,pro tools cant keep up during play back fredson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 41 01-26-2009 09:51 AM
Play by play coverage of my Pro Tools MADNESS! test tube AUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-16-2005 06:23 PM
my pro tools won't play! nny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-04-2001 12:48 PM
