Old 04-24-2004, 11:23 PM
music project music project is offline
Default so can you realy mix a rock band inside protools..
can you realy mix a rock band inside pt le with the bundled digi & bomb factory plug ins ?
let's say i have 30 tracks of audio , can i aply a comprresor&eq to every channel and have some
3 or 4 loop fx (reverb delay) in my sends ?
my set up is :
p4 2.8
1 g ram
intel 865e chipset
2009 8 core mac pro "nehalem" with 6GB ram, 002R, command 8, pt 10.3.5
Old 04-24-2004, 11:29 PM
Default Re: so can you realy mix a rock band inside protools..
If your track is recorded well.. there shouldn't be any need to use anything near that many EQ's and compressors... Spend the time and use good outboard gear and record the tracks well.. and you shouldn't have any issues mixing in Pro Tools.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-25-2004, 12:09 AM
TheLP TheLP is offline
Like rail said, you shouldn't have to use plugs on each track, you make it sound like the plug-ins are what make the music. Its pretty hard to reach 32 tracks when your just recording a rock band, that probably has 2 guitars, a bass, and a drummer.
[TheLP]
Old 04-25-2004, 04:13 AM
i was just intrested in the systems resorces capebilities....
Old 04-25-2004, 04:33 AM
katoramone katoramone is offline
You'll be fine. I use a AMD 1.6Mhz and 1gig Ram with an AudioMedia3 card for mix, you can run EQ's till your sic, even compressors as well. Digi reverb are ok but like all reverbs they start to use up power. Like the above said, just capture the best sound you can, mixdown isnt for fixing things but for making things fit better.(make sense?)
Old 04-25-2004, 06:13 AM
yup, thanx
Old 04-25-2004, 06:58 AM
Chris Cavell Chris Cavell is offline
my set up is :
p4 2.8
1 g ram
intel 865e chipset
With just the digi and bf plugs...no problem; But why on earth you'd like to apply this amount of processing is beyond me...but every engineer is different, if that's how you want to do it...you can.
Cavell Studios
Old 04-25-2004, 07:02 AM
Joe Evans Joe Evans is offline
Run the DaveC test that you can find on this forum. That will give you and idea of the resources that your system has for use. Be aware that this test doesn't really show real-world capabilites, but it might give you an idea of how far you *can* go. I hope this helps.
--joe
--joe
Old 04-25-2004, 10:11 AM
nikki-k nikki-k is offline
Hi!
See the gearslutz forums, April guest moderator section. Charles Dye is there, and he did the Hard Disk Life column in the Digizine. Interesting stuff...
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
Old 04-25-2004, 10:40 AM
Telepc Telepc is offline
It can definitely be done:
An example for you
That's my band recorded live and mixed entirely with ProTool LE. Pretty good results if I do say so myself, so just imagine if it had been tracked in a studio environment with channel isolation.
(Oh yeah, and I didn't need to use that many plugins either, but I have a 4-band EQ on just about every track, a compressor on a few, a limiter on a few, aux sends for vocal effects, and about 3 plugs on the master track--didn't even come close to maxing out my system).
Finally, this was done (as you inquire) entirely with the included Digirack & BF plugins. I have no doubt that a more expensive set of plugs on the master track might have made a better master, but again, I think my results show up quite well.
Digi002-R
14" G4 I-Book 1.33 GHZ, 1.25 Gb RAM.
Seagate 160 Gb ext. firewire HD
ADA-8000
Soon very soon...this may be the average rock band GORILLA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 11-19-2003 12:01 PM
Band I mixed recently in PT6.0.2... (mp3 inside) audioeric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-09-2003 11:06 PM
Here comes that rock band!!! Help! The Fez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-21-2003 09:45 AM
Recording a Rock band with the 001 peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 45 05-24-2002 11:01 PM
4-pc rock band recording blake eat world 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-14-2001 10:55 PM
