Old 12-05-2008, 09:15 AM
Yodah Yodah is offline
Default Command 8 vs. 002 Console
I have had a console for 5 years. Now I have a SigMod 002 and someone is selling me a command 8 for 350! (getting out of protools)
So, is there any new things ....function wise that I may have to get used to.
And does it make a difference how you route your monitoring....guessing it would be better for me to monitor through the Sig002 oppose to the command 8.
PT 2019.5 on Mojave
MacPro Late 2013 6 Core 64gb 512ssd
Slate Raven Mti2 Core
Apollo X6. Apollo Twin.UAD2 Satellite
BLA XB Clock
SSL Fusion
Old 12-10-2008, 12:16 PM
SKI's Avatar
SKI SKI is offline
Default Re: Command 8 vs. 002 Console
If you are planning to use the Command 8 with a 002 Console then it won't really matter since all you can do with the Command and 002 Console is use the Command to add 8 additional faders, nothing more.
Also remember the monitoring on the Command 8 has nothing to with PT, it simply acts like any other little mixer you might use.
You feed it a signal from your Digi interface and it gives you some control over the signal.
URBAN MUSIC-
(Hip Hop and R&B)
Old 12-11-2008, 07:05 AM
Thanks for the answer, I guess its a two question post.....I know longer have the console......just wondering if there is any difference/advantages in owning the command 8 over the console as far as ProTools is concerned. Second part.... if I connect my monitor outs from the 002r to the command 8 instead of the 002r directly into monitors, won't I be monitoring through the command 8's analog components..... Or is the command 8's monitor section just a past thru that will not effect or degrade the much better D/A coming out of the modded 002.
I guess I could answer that question myself......do it and see what happens!
PT 2019.5 on Mojave
BLA XB Clock
SSL Fusion
Old 12-11-2008, 09:55 AM
SKI's Avatar
SKI SKI is offline
The Command 8 doesn't have all the changes that the 003 provides but it definitely has a enough as to where it has a much better flow than the 002 Console.
The monitoring section on the Command 8 isn't an advantage.
URBAN MUSIC-
(Hip Hop and R&B)
D-Command users- What do you use for a console stand? Will Russell ICON & C|24 19 11-25-2012 02:42 PM
Digi 002 Console with Icon D-Command Encoder Knobs Benprogfuse ProControl, Control|24, Command|8 4 08-31-2012 03:09 PM
D-command and digital console nobi71 Pro Tools TDM Systems (Mac) 0 08-02-2010 11:31 AM
command period equivalent on 003 console Traveler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-30-2007 03:31 PM
New D-Command Studio Console Rezman ICON & C|24 18 07-30-2005 09:30 PM
