Making Session Start/Bar 1 later in Video
Hi
I was wondering how to make the session start/Bar 1 later in a imported video? For example, I import a video, first frame of the video is 09:59:00:00 and my sessions is synced up with session start also 09:59:00:00. When I hit play and check throughout the SMPTE is lined up. But what I now want to do is make my bar 1 later in the video say SMPTE 10:30:00:00. But I also want my session start at Bar 1 so there are no minus bars in my session. So I can start writing music from the start of my session and it will be later in the video, not at the start of the video? For example, for those of you that have logic. I import a video in Logic and sync the video in the movie tab, so that the timecode matches in logic with the timecode burn in the video. Then I can make logic start later in the video by going to the Synchronisation tab and setting bar 1 to a later SMPTE time that I want the session to start at. Can I do something similar in Pro-Tools? |
Re: Making Session Start/Bar 1 later in Video
Yes you can, using the tempo ruler. But unlike Logic, you can't have a video in Pro Tools that starts before the session start. Unless you trim the video. But don't do that. It's always good to have a lot of pre-roll. Live with the 'minus bars' and carry on.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Event menu: move song start and renumber bars are your friends...
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Hi
Ok, so I can set Bar 1 to a later SMPTE and live with the minus bars. But I have 2 questions then - If I change the tempo then Bar 1 will move to a different time code? If I lower the BPM then Bar 1 is later in the film etc. Is there any way to lock bar 1 to a specific time code no mater the tempo? - If I hit rewind to start, it jumps back to session start, in the minus bars. Is there anyway to make rewind jump to Bar 1 overtime as default? Thanks |
Put a tempo event at bar 1 beat 1
Use memory locations
This may not be feasible in a lot of cases, as you probably don't want to lose the beginning of your video. But if what you are trying to set as bar 1 is actually the FFOA, it could be a workaround for you (assuming you change your session start time back to something more standard before delivering to the mix stage, of course). |
Mov/Avi making PT lag, mpeg/mp4 video doesn't appear in video Window | Fletch88 | macOS | 3 | 08-28-2011 01:26 PM |
Sharing a video in same session for ADR (video in booth and video in control room) | Boogie457 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-01-2010 04:52 PM |
Making matching start times yourself? | M55ikael | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-09-2006 07:45 AM |
Can I start Playback at Session Start Time? | LSW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-19-2006 03:04 PM |
Pro Tools 5.1 Session Start—Record Start Interval | Avid | Pro Tools TDM Systems (Mac) | 4 | 04-18-2001 08:27 AM |
