Old 09-30-2014, 04:32 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: HELP - Eleven Rack Expansion Pack
Have you tried uninstalling the 1.1.7 driver and try using the older 1.0.8 driver.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 09-30-2014, 10:44 PM
txrx txrx is offline
At last the PROBLEM is SOLVE by changing USB PORT.
Old 10-05-2014, 01:20 AM
zedhed's Avatar
zedhed zedhed is offline
As a matter of interest, was it changed from USB3 to USB2 port?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 10-05-2014, 09:43 AM
Benoni's Avatar
Good point. I'm interested in this as well.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 10-15-2014, 05:08 AM
J.LaGrassa J.LaGrassa is offline
I just bought a used Eleven Rack with firmware 1.03 I would like to update to ver 2 but kind of afraid to try based on some posts I have read with issues, I use Windows 8.1. I almost gave up on the 11R but decided to keep at it so I would like to get the latest firmware installed... I might just take a chance!
  #16
Old 10-15-2014, 09:09 AM
Benoni's Avatar
I've never tried the update on Windows 8, so I'm not sure what to expect. But there is an incompatibility with having Internet Explorer 9, 10, or 11 installed and running the ERXP Firmware updater.
So I would make sure none of those are on your PC before you try the update.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #17
Old 10-15-2014, 09:42 AM
Yeah I read about IE as well, I have IE 11 but dont use it so its a good excuse to uninstall it. Hopefully Firefox is ok!
  #18
Old 10-15-2014, 09:52 AM
Benoni's Avatar
You can reinstall IE after the firmware update is complete. It's only the actual installation that is incompatible, once it's installed, everything is fine.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #19
Old 10-16-2014, 07:28 AM
I went to uninstall IE11 but with Windows 8.1 you cant uninstall it, its now a Windows feature so all you can do is shut it off. I did shut it off and don't see any traces of IE on my computer so maybe that procedure is similar to uninstalling.
I still have my old computer with XP, you think I should do the expansion pack upgrade with that computer it might be a safer way to get it.
  #20
Old 10-16-2014, 09:46 AM
Benoni's Avatar
Yeah I didn't think it could be completely removed from Windows 8. I can't tell you for sure if the XP computer would work, what I can say is that at the time the ERXP was released it worked fine on XP.
Again make sure you have the 11R drivers installed, the older 1.0.8 driver was the current driver at the time, and make sure you have no more than IE8 installed on the XP PC.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Eleven Rack II or Expansion Pack II ? ofp Eleven Rack 51 07-22-2013 08:36 AM
Eleven Rack Expansion Pack and PT 10 dckerley Windows 6 12-14-2012 01:16 PM
Eleven Rack with Expansion Pack Hendrix95 Buy & Sell 2 07-21-2012 06:44 PM
Eleven Rack Expansion Pack Legion6789 Eleven Rack 6 01-10-2012 10:23 AM
Eleven Rack Expansion Pack Hank Marvin Eleven Rack 16 08-31-2011 06:12 PM
