What kHz Tone to Generate for Tone generator
Whats the Tone to Generate that most people use when in the beginning of whatever to set levels using tone generator in PT.
ex: 4kHz 2 sec tone? etc... |
Re: What kHz Tone to Generate for Tone generator
1 khz
In the analog days it was 100hz, 1khz, 10khz, then sometimes pink noise, 16k, and 40 hz. then a record pad. |
for example ludicrous, when u give a cd to a broadcast radio station and that cd u have everything mixed to 0 (nominal level) there machines will slowly fade your music up to nominal without a tone. but if u but a tone before your broadcast starts that sudden noise if set the same to ur levels (0 , nominal) will set there broadcast to the level u wished to be set at immediately, rather then a fade in noise which may or not be prefered. you may want your broadcast to start immediately at 0 , nominal level. so u need to set a tone for the computer to detect the levels u wish.....
and if u have the wrong tone which i did, 4 khz , it sounds a whole lot louder then 1 khz tone and therefore making my levels sound diff even tho 4 khz at 0 db was the same as my mix at 0 db, but 4 khz at 0 db sounds twice as loud as a 1 khz tone at 0 db.... |
room tone extract and generate plugin | Guruman | Post - Surround - Video | 12 | 04-20-2007 07:05 AM |
Tone Generator / Automation problem | Archmart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-17-2005 09:03 AM |
Test Tone Audio File or Tone Generator | Imagine | Pro Tools TDM Systems (Mac) | 4 | 04-15-2005 06:28 AM |
How can I cheaply generate a 1 khz, +4dbu/0VU tone? | MarkGenero | Pro Tools TDM Systems (Mac) | 19 | 01-04-2002 07:50 PM |
Tone generator recommendation | tld | Tips & Tricks | 8 | 11-27-2000 10:47 AM |
