#21
Re: What do I need to monitor in Dolby Atmos with my setup?
Yes. DADman comes with it. (downloadable from Avid or from DAD -- right now the newest version comes from DAD) (get it together Avid!) Quote:
And you haven't got into configuring the S6 which can/will run higher than even you think for the bells and whistles. *and just some corrections: it is "SPQ card" (speaker equalisation) for the MTRX not PSQ and the Dolby unit is "RMU" (rendering and mastering unit) not MRU
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#22
Thinking about it, Spanner
http://thecargocult.nz/spanner.shtml Is the only plugin/iPad app (it operates outside of Eucon so it doesn't matter about that) that I know of that does allow panning in 7.1.2 with an iPad control. However, you aren't using Avid's integrated panner this way.
#23
Well I think right now the spanner plug in is the only way I can do atmos panning in conjunction with the ICON... unless of course I'm using the mouse... which will just suck.. I mean all this stuff should have really been discussed before getting all these speakers installed... but that what I was given when I walked in the job 2 weeks ago, so I'll do my best to get it working! So my cheapest option right now from my understanding is: 1 x AVID MTRX Base Unit 3 x 8out card Dante 64IO card SPQ Monitor Card 1 x DAD MOM ( just because I want a volume control knob!) 1 x extra HDX card 1 x Ipad 1 x Spanner App + AAX plug ins for panning 1 x Dolby Atmos Production suite Am I missing anything? right now I'm looking at just over 20K USD Eventually will get an S6 as I'm sure they will want to future proof the setup, and all that gear will be useful for that setup too.. but right now I'm not sure they will fork out another 80K on top for that 20K.. |
#24
What are your speakers (make/model)?
If they can be digitally fed (AES, Dante, etc.), you can cut a few thousand down out of your costs by not needing the MTRX Analogue cards. The base unit has quite a lot of digital built in and you could supplement with cheaper MTRX cards (dante daughter module, AES cards, etc)
#25
And also the system is a 13.1.6, not a 15.1.6 like I originally mentioned... Looks like the MTRX comes with 16 mono channel of AES, so potentially that could take care off all 10 side and back speakers, then I would still need 2 analog I/O card for all the ceiling / front speakers and LFE |
#26
1. Spaner is very cool, but personally I enjoy panning with a touch screen about as much as paying with a mouse. Also, having to use the Spanner plugin instead of the PT panner isn't the best option for teaching, IMO. As another option, consider the JLCooper joystick (someone mentioned in a previous post). I have an old model that I've used with Atmos. Here is the new model (USB): https://www.jlcooper.com/_php/product.php?prod=axos Here is an old one (MIDI) on Ebay: https://www.ebay.com/itm/JL-Cooper-J...0AAOSwXetZSKz2 2. You don't need the Dante card if you are using AES or analog. But those analog cards are reeeeeeeally expensive. BScout is right- double check what your speaker connections are. figure out what is behind that screen. Maybe you can go with only the Dante card, and use some CAT6-to-XLR adapters to send signals to each speaker: https://www.audinate.com/products/da...e-rjd1112-0050
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#27
as a cheaper alternative would this work?
1 x JBL Intonato 24 Monitor Management Tuning System ($3000) 1 x Dolby Production Suite for Protools ($300) 1 x JL Cooper Nuage panner ($1500) ( Does it work with Protools built in Atmos panner?) |
#28
Don't get the Nudge panner. I think that connects with ethernet and not might be proprietary. Besides, the housing is made to drop into the Nudge console. The AXOS is right one. Or the older model that works with USB. I prefer that one, because it only sends pan information when you push the joystick button. See both links in my last post.
The Intonato is good for room tuning and monitor control, but you still need a protools interface to get the sound into it. And not that you get get the room thing card for the MTRX, you could use the MTRX for everything. (Although, I haven't used the monitor tuning card personally. But it looks good)
#29
The Intonato works well if you are on JBL speakers it supports. The 7 series speakers are supported. Your others, don’t know. You’ll need to talk to JBL. It isn’t quite as universal as JBL pretends it is. (There are features in room correction that aren’t expanded enough to handle many speakers and non-adjustable things)
And I do understand: the SPQ card is US$2200 alone while the Intonato is US$2999 for the whole thing. (Plus Avid HD I/O are cheap compared to the MTRX). Just make sure the Intonato works for your setup. You can get one in and make sure before committing.
#30
Ouch. I didn't know the speaker tuning card was $2200. And at $2999, there are better options over the Intonato. The QSC Q-Sys 110f is one of them. So he could do an HD I/O and run analog into the QSC and off to the speakers.
https://www.qsc.com/de-new/systems/p...res/core-110f/ I use the 250i. The QSC stuff is amazing. It'll hand the room tuning and the monitor control (via iPad). You can program it to do anything you want.
Dolby Atmos with S5 MC-Pro | critictalk | Post - Surround - Video | 4 | 01-01-2018 08:21 AM |
Dolby Atmos Monitor Controllers | PT user | Post - Surround - Video | 16 | 08-09-2017 07:58 AM |
Dolby Atmos | IrelandM | Avid Pro Mixing General Discussion | 2 | 07-17-2017 01:00 AM |
Dolby Atmos - Do I need SRC? | budster | Post - Surround - Video | 4 | 03-24-2015 10:25 AM |
Dolby Atmos | peter5992 | Post - Surround - Video | 20 | 10-29-2012 01:51 PM |
