Batch fade out on SAME TRACK
I would like to know if I can take the 200 clips I have on the same track, select them all and make a fade out that will apply to all those clips? The only thing I found was with CMD-F, it would apply a fade in AND a fade out... I only need a fade out. It's easy doable on different tracks, but I can't seem to find the way to do this on one track. Thanks |
Re: Batch fade out on SAME TRACK
I would like to know that too... but I guess its not possible...
Often I do a strip silence on a Kick drum and like to do a quick fade in (3-4ms) and a slow fade out (+/- 50ms) But the Batch Fades only support a single time length for both in and out. Hope someone brings up a smart idea
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11 16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1 MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch + madi baseunit + optical SFP 1300nm MOM v.1.0.1.4 by DAD Genelec 1237A Sam, Avantone active mixcubes LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro Furman P1400 AR E Power conditioner Live-rack: 1x HD Native TB, 4x 192 I/O (64ch AD) 8x Yamaha HA-8 micpre, Rosendahl mif4, Genelec 1031A, Presonus Monitor Station |
So I've done a 300ms fade out, with a fade in around 100ms. You can see on the waveform it has actually done this, but has drawn the fade in point as though it is a 300ms fade in. So I admit there could still be a better implementation, but batch fade in/outs of differing lengths are NOT impossible. |
I don't need different length fades, but just batch fade everything on the same track. My workaround is this: |
Thanks suicune,
Didn't know that one... I'll try that on my next project... Gotta love this forum... the wisdom off all users
But what I do when I clean kick drum tracks, I simply use the default 10ms fade after properly set up Strip Silence tool, so I don't affect the kick sample very destructively. Then later on, I sculpt the sound with a gate (which is now a sound design tool because unnecessary stuff has already been cleaned away...)
Batch fade-out | SteveFireland | Tips & Tricks | 4 | 12-20-2012 05:32 PM |
Batch Fade Trouble | MagicEscalator | Pro Tools TDM Systems (Mac) | 0 | 09-08-2009 07:09 PM |
Feature Request Batch Fade In and Batch Fade Out | mariang | Pro Tools TDM Systems (Mac) | 2 | 02-07-2007 01:32 AM |
Why does batch-fade leave out first and last fade? | Frank Kruse | Post - Surround - Video | 5 | 03-08-2006 03:47 PM |
batch fade | Xplosvebob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-07-2002 03:00 AM |
