Old 04-25-2006, 01:30 PM
TrevorForrest TrevorForrest is offline
Default Firewire Solo and Firewire External Drive
I am currently using an M-Audio Firewire Solo. I have connceted an Iomega external Drive to the second firewire port on the Solo. I seem to be getting lackluster performance when mixing and editing session stored on this drive as compared to doing the same thing with sessions store on the system drive of my laptop. The system drive on my laptop is a 5400rpm drive and the external iomega is a 7200rpm drive. Is this supposed to happen ????...i thought i would see better performance with the external drive connected via firewire to the M-Audio Firewire Solo interface.
Old 04-25-2006, 02:29 PM
spkguitar's Avatar
Default Re: Firewire Solo and Firewire External Drive
Digidesign recommends using external drives with the Oxford911 firewire bridge chipset. I'm not sure what's in the Iomega, but this might be one of your problems.
Old 04-26-2006, 01:07 PM
jp_dt jp_dt is offline
I've found connecting a firewire drive to the same bus as an m-audio interface to be lackluster whether you use the recommended drives and chipsets or not. There are other reports on this board that share that experience. My particular interface is the fw410.
SpkGuitar, have you had success with this configuration...m-auido device and f/w drive on same bus?
Old 04-26-2006, 03:43 PM
spkguitar's Avatar
Yes, I use my Ozonic like that all the time; m6811 Laptop->Hard Drive->Ozonic. No problems.
Old 04-26-2006, 03:45 PM
spkguitar's Avatar
Also, now that we can run LE and MP on the same machine, I've also used my 002r in the same manner; laptop->drive->002r. No problems.
Old 04-28-2006, 02:50 PM
uncoiled uncoiled is offline
Slightly off topic, but is it better to hook the external drive before the interface rather than the other way around? Does it make a difference either way?
asysttheband.com
uncoiledmusic.com
Old 04-28-2006, 02:59 PM
spkguitar's Avatar
That is the recommended method, yes.
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
What can I put on my external FireWire Drive? mgtube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2010 03:31 PM
Using external clock with Firewire Solo geishaboy Pro Tools M-Powered (Mac) 3 09-03-2005 11:42 PM
How can you use an external firewire drive and Digi002 with only 1 firewire port? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-16-2003 01:11 AM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
