Old 05-07-2008, 08:32 AM
dlipsjr dlipsjr is offline
Default Mic 3-4 Input Issues 003 Rack
I am not getting any signal into my mic lines for channel 3 and 4 on my 003 rack. I tried going back to my default path settings just in case that may have been the issue but nothing changed. Yesterday was the first time I had attempted to use all four mic lines so they may have been screwed up from the beginning. I got one of the first 003 to hit the market...anyone else run into this problem.
Old 05-07-2008, 10:49 AM
@ndy's Avatar
@ndy @ndy is offline
Default Re: Mic 3-4 Input Issues 003 Rack
I had problems with input 3 & 4 on my 003 rack (one of the first shipped). The phantom power would not work. I called Digi and they sent me a PDf with directions on how to fix it. It was a loose connection caused by the wiring harness. I was able to fix the problem faster than it took me to un-rack the unit. Maybe you have a similar problem. I would call Digi. Good luck.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Old 04-12-2011, 05:18 PM
jrichter jrichter is offline
I have the same problem with my 003 Rack, have you solved the problem with yours and how did you do so?
Thanks
Midi input issues PT10.3.5 003 rack+ animalaudio macOS 2 06-25-2013 05:45 AM
Input issues... ROBB007 Pro Tools 11 1 04-23-2013 10:24 AM
Digi 003 rack ,input issues :( kankzzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-12-2012 12:48 PM
Input issues! zoemurakami 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-10-2011 07:23 AM
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2003 04:08 PM
