Old 02-13-2008, 04:37 AM
dmty dmty is offline
Default motherboard for Protools HD accel core card for PCIe
anyone have experience with motherboard compatibility with the accel core card ?
trying to see a good set up for my comp
Old 02-20-2008, 05:23 PM
BradLyons BradLyons is offline
Default Re: motherboard for Protools HD accel core card for PCIe
There is an issue using ProTools Accel cards on a Windows PCIE motherboard because of the relation of PCIx and PCIe motherboards, not that the cards technically won't work--but there is a limitation in the flex cables that connect the cards. Therefore on the PC, there are no Windows installers for a PCIe system at all. In other words, you need PCIX for your motherboard and an HD system.
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 02-22-2008, 11:34 AM
Paul S-Tone Paul S-Tone is offline
Sorry no true ! .
i have HD3 PCIe on PC and work very solid !
Motherboard AM2 Gigabyte GA-M55S-S3 (rev.2)
ciao ciao !!
MacPro PTHD 3 PCIe
Protools Lovers
Old 02-22-2008, 02:28 PM
Well if you have a PCIe motherboard with all the slots next to each other then technically it will work, however Digidesign does not have specific drivers for the PCIe card on Windows. If you're running it and it's fine, great--but to the best of my knowledge unless this has changed recently--it's not officially supported.
(404)844-9758
blyons@gcpro.com
Old 02-27-2008, 06:11 AM
raga2000 raga2000 is offline
hi paul,i miss your system report.can u send me what ram,cpu,grafic and hdd u usealso what is your power supply.
regards
iman hojjat
ragastudio2000@yahoo.com
nobody can run pt hd pcie in pc like me!!!hahaha...
Old 02-27-2008, 06:12 AM
also do u test intel motherboard for hd2 pcie?hw about intel?
iman hojjat
Old 03-08-2008, 01:18 PM
Mark879 Mark879 is offline
I'm fairly new here so take this with a grain of salt. After trying several motherboards I found gigabyte ga-ep35-ds4 works for me using HD|2. If you use two cards you will need a videocard that takes up only one PCI 16 slot (not two). The two cards fit it fine and did not obstruct any important features on the board. On other boards the PCIe slots the boards will hit your RAM boards. Also, another lesson I learned. Make sure you computer case is large enough that the card or cards fit, ie. they don't run into your hard drives, etc...Hope this is helpful.
PT HD1 (core card PCI) x PTHD1(Accel core card PCIE) Alécio Costa Pro Tools TDM Systems (Mac) 6 05-02-2017 07:52 AM
FS Accel Core Card PCIe Raoul23 Buy & Sell 1 02-13-2013 10:30 AM
WTB: 1-ACCEL CORE PCIe CARD postman56 Buy & Sell 2 01-23-2013 07:06 AM
FS: HD2 Core+Accel Card PCIe Meads Buy & Sell 24 12-30-2012 06:59 AM
FS: HD1 Accel Core PCIe card Captain Audio Buy & Sell 0 05-15-2012 11:19 AM
