Problems with Pro Tools 9 and Focusrite Saffire
Hi guys. I'm kinda new to audio recording and I got some starting problems..I got this focusrite saffire device that look like this
And I have tried to install latest focusrite drivers that say it supports PT9, but no luck. I still get this "Your audio device is configure with an unsupported audio buffer size. Please select one of the following supported buffer sizes in the device control panel: 32:64; 128; 256; 512;1024;2048". I can't open PT so I have no way to change buffer size it seems. Please help ! |
Re: Problems with Pro Tools 9 and Focusrite Saffire
The Saffire should have its own control panel, can you set the buffer there?
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
I can change sample rate but not to the values that pro tools ask for. I can change to 44.1 48 88.2 96 and 192.
I'm sorry for these stupid questions! I'm as I said, very new to his modern audio recording stuff. Thanks for your reply |
quick update. I downloaded the asio4all driver. And then I managed to change buffer size to 128 in ableton through the asio4all driver, and then I were able to enter PT 9. But when I tried to play my session I get only a clicking sound from my monitors. I also changed the buffer size in PT to the same value.
Also. I have as I said earlier updated the focusrite saffire driver but when I have tried to update the firmware I get an error. Is this important? |
What kind of computer specs do you have?
Microsoft Windows 7 Home Premium
6.1.7601 Service Pack 1 Build 7601 System Model MS-7798 x64-based PC Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz, 3400 Mhz, quad core BIOS-versionAmerican Megatrends Inc. V1.0, 26.03.2012 SMBIOS-versjon 2.7 RAM 16,0 GB |
Hi SheikYerboti,
In order to use your specific saffire interface you will need to download a windows legacy firewire driver. Here's a step by step guide on how to do that: http://global.focusrite.com/answerba...dows-7?id=1030 |
I have no problem using the saffire with other programs like ableton liv,adobe audition etc. Only problem is with Pro Tools 9. And it seems like I need to download the Saffire mixcontrol wich i don't think is compatible with the model I got. Correct me if I'm wrong
Legacy FireWire - I assume that the interface you have is older?
I installed the legacy driver but I still get the buffer size prompt when starting up pro tool9 , and it kicks me out so I can't even get in the program. I'm totally lost now
Focusrite Saffire Pro 24 & Pro Tools 9 | AfterJohn | macOS | 17 | 03-31-2012 12:27 AM |
Focusrite liquid saffire 56 and PT 9 BIG PROBLEMS! | jarrydee | Windows | 17 | 12-27-2011 02:01 PM |
PT9 with Focusrite Liquid Saffire 56 problems | RustRecording | macOS | 4 | 07-27-2011 03:38 AM |
Pro Tools 9 with focusrite liquid saffire 56 problems | johanonsydow | Pro Tools 9 | 24 | 02-18-2011 06:21 AM |
Pro Tools 9 and Focusrite Saffire 40 how to add inputs | connoyeah | Pro Tools 9 | 2 | 11-16-2010 09:53 PM |
