Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-16-2021, 11:26 PM
beatwave beatwave is offline
Default discard changes backward editing using playlist shortcut
(I'm not good at using English, please use easy English, Thank you!)
In coping audio from other playlists(Cmd+Shift+up arrow or down arrow), backward editing from current selecting is discarded.
This unexpected behavior do not work always, but happen when toggling audio to the last(bottom) playlist and just backing to main playlist.
This situation occur in PT 2020.5(HDX System) w/MacOS Mojave.
Anybody knows how to prevent this?
Thank you.
Old 04-17-2021, 07:06 AM
Default Re: discard changes backward editing using playlist shortcut
I don't understand the problem so I will just offer a method that may help. It sounds like you are copying clips between playlists and then trying to undo? My method would be to add a new blank playlist and send the desired clips to that playlist, only. Doing this means that the other playlists do not get messed up in any way, and the "comp" playlist can always be cleared of any/all audio.
You also should scroll to the lowest area of the DUC main page as there is a section for other languages
New Playlist shortcut? Mix Master Factories 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-03-2010 03:32 AM
New playlist shortcut? jdutaillis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-20-2009 10:22 PM
New Playlist Shortcut zwiersd Pro Tools TDM Systems (Mac) 1 04-23-2009 04:51 AM
Shortcut for NEW PLAYLIST ? John Edwards UK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-22-2008 06:25 AM
Shortcut for "New playlist" FrauMitBart Pro Tools TDM Systems (Mac) 1 04-01-2005 12:57 AM
