Old 03-22-2021, 11:23 PM
Mark Ziebarth Mark Ziebarth is offline
Default Working with several EuCon hardware
I use my Mac mini at two different locations: in the studio with a rusty MC Control and at home with a Dock. With the Dock everything works excellent but the Controls wheel looses its functions every day. The zoom and clip start/end functions are on soft keys to assign what the wheel should do but the commands get lost everyday. I guess the save operation doesn’t work.
Is there a way to have separate EuCon settings per mac user account?
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 03-23-2021, 07:40 AM
EddieJones's Avatar
Default Re: Working with several EuCon hardware
Are you saying that when you go into the Softkey tab in EuControl the commands are missing, and if you put them back and press save they don't? One thing you could try is using the Export and Import, this way you can have multiple different softkey settings.
Old 03-28-2021, 05:20 PM
Thanks Eddie, I will give it a try.
Best
Mark
Old 04-27-2021, 11:28 PM
Hi Eddie,
I checked back and found out it was mainly a problem with the rights management of macOS. The save Command still doesn’t work but Export works.
Is there a way to switch the appset automatically with the corresponding user? In my case: If I start the „studio“ user the appset for MC Control loads and when I‘m at home with the „home“ user the appset for the Dock loads automatically?
Actually I have to import MC Control appset each time I‘m in the studio.
Thanks for your help.
Best
Mark
Old 04-28-2021, 08:24 AM
EddieJones's Avatar
Unfortunately not, sorry
Old 04-28-2021, 10:31 AM
So here comes my update wish: If the standard appset file can be whether in the main library OR in the user library with a priority for the user library my problem would be solved, wouldn’t it?
Best
Mark
EUCON 3.2.1 not working under 10.8.5 and PT12 SD2 Artist Series 4 06-04-2016 01:39 AM
Eucon Commands with other Hardware kava Artist Series 3 12-23-2015 04:29 AM
EuCon 3.2.2 still not working with Logic Pro X romanoffski Artist Series 3 04-13-2015 09:32 PM
Eucon not working with 11.1.3 Frank Kruse Artist Series 11 05-20-2014 09:41 PM
Euphonix EuCon 2.5.2 - Pan Not Working Carl Sealove Pro Tools TDM Systems (Mac) 3 01-20-2010 07:04 AM
