Standalone Core Audio Driver OSX Lion
hi,
I'll admit to failing in trying to learn Pro Tools 8 - as I'm an off and on recording person. It's my kids' fault... anyway... I now try to use Logic. I have an MBOX2, Aluminium iMac mid 2009 and OSX Snow Leopard, running the Standalone Digidesign CoreAudio Drivers v8.0.3 for Leopard and Snow Leopard. I have found the MBOX2/ core audio does a weird thing where it repeats noises (like an echo/loop of, for example, the 'you have new mail' sound) and seems to crash all the time. Going into Audio Midi setup and changing the Sample rate from 48 to 44.1 or in reverse then seems to 'reset' the MBOX2 - and it works until the next Sleep. Then it misbehaves again. My question is: I want to upgrade to Lion, and I want to know whether there is going to be a Standalone CoreAudio driver for Lion for the MBOX2. There is some twitter talk about Lion not being able to connect to the MBOX2 at all. I am hoping that Lion and a new Standalone CoreAudio driver will fix all of my problems. thanks |
Re: Standalone Core Audio Driver OSX Lion
wait. give pt 9 a chance should work great with what you have. did you try tutorials such as www.lynda.com or www.groove3.com they will teach you anything. You got enough technology for the next 20 years already...
Everyday Is A Good Day http://www.bandmix.com/itzhak/ My Music www.itzhakyaron.com |
The standalone audio drivers may be in conflict with Pro Tools. I think the standalone drivers are supposed to be used when you don't have PT installed.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Sorry for not being clear.
I have uninstalled PT8. If required, I could reinstall PT8 when the Lion fix comes out... Does anyone know if they are writing a Standalone Core Audio Driver for OSX Lion? I'm sure there are many like me who just use MBOX equipment without PT. thanks |
Digi CoreAudio Manager 9.0.3 should work with Lion...
it's not required for Pro Tools Software. |
I doubt PT8 will ever be Lion compatible, but I could be wrong.
OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty |
Thankyou Baba Omar Jun - you are correct.
Installed MBox2 Driver v9.0 - worked fine under Snow Leopard. disconnected all USB devices before installing Lion. Lion installed aok. After install - Lion said: "some incompatible software has been put in the "Incompatible Software Folder" in root directory. Pro Tools is not compatible with Lion." Because i did not have PT8 installed (just the drivers) - the only files moved to the incompatible software folder were MBOX2 USB DRIVERS - 3 of them (all dated October 2010.) I assume that Lion moved those files on the basis that Pro Tools (the program) is incompatible. the USB device drivers are not - so install them again... Ran the MBox2 USB Driver 9.0 again. Plugged in the Mbox 2 - Works fine. haven't had time to test Logic Express 9 - but I'm sure it will be fine - seems to connect to the Audio Midi Setup perfectly. Thanks again. |
The CoreAudio Drive v9.0.3 is working with OSX Lion for Pro Tool HD | 192 I/O with Logic Pro 9.1.4... but not compatible with Pro Tools v9.0.3 software...
I'm again feeling that reading is becoming a lost art...
... and it works until the next Sleep ... You have to disable sleep when running Pro Tools. So, follow the recommended instructions (including optimizations) and reinstall what you alread have. And for those of you who are trying to be helful, you really need to read the entire post before responding...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
More lessons from the DUC's schoolmarm.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Standalone Core Audio Driver for HD System? | dforden | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-19-2013 02:18 PM |
Standalone Core Audio Driver for 002r and 10.5.3? | ethansch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-22-2008 10:50 AM |
Is there a standalone core audio driver for new | imported_tupelohoosier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-13-2006 02:25 PM |
standalone core audio driver for Tiger | soulextending | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-03-2005 11:19 AM |
standalone core audio driver - when ??? | The Lone Roger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 07-26-2003 06:01 AM |
