Cannot get rid of Pro Tools Aggregate I/O after uninstall of Pro Tools 9
I uninstalled Pro Tools 9.0.6 from my iMac Retina 2015 running macOS Mojave, removing what I thought were all the associated files. Yet despite this whenever I start up my Mac the audio output defaults to the Pro Tools Aggregate I/O and I cannot seem to permanently remove this from my system. I am using Logic and want to completely wipe all remains of Pro Tools. Is there an uninstaller that can do this? Why does this Aggregate I/O device keep reappearing? Any help greatly appreciated! |
Re: Cannot get rid of Pro Tools Aggregate I/O after uninstall of Pro Tools 9
Audio MIDI setup in Utilities folder in your Applications folder is where you can remove it.
Sent from my iPhone using Tapatalk |
Thanks for your suggestion - I have already tried this countless times. Makes no difference as the Pro Tools Aggregate I/O just gets repopulated in the list of devices in Audio MIDI setup after restarting the machine.
Thanks, Charley |
Hmmm... that’s curious.
If you don’t delete it, select a different interface for system audio in System Preferences, does it stick on reboot? There should be no reason why it changes that setting on its own. Sent from my iPhone using Tapatalk |
Do you have another version of PT installed? If so, every time you start that it will recreate the aggregate device.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Hi.. no - I only had Pro Tools 9.0.6 installed on the Mac. There must be some files hidden somewhere which weren't deleted which make the system think PT is still installed..?
Unfortunately it doesn't stick on reboot, instead it defaults to Internal Speakers and the Pro Tools Aggregate I/O still appears in the list. I have an RME Babyface Pro which is what I would like to be the default output.
Pro Tools Aggregate | esmallwood | Avid S1, S3, Dock and Control App | 5 | 05-12-2016 11:49 AM |
Pro Tools Aggregate i/o | storkindeutschland | Pro Tools Express on Mac OS X | 3 | 08-30-2014 08:30 AM |
Pro Tools Aggregate I/O | ggkarman | macOS | 24 | 09-10-2012 01:01 AM |
Pro Tools Aggregate I/O | GTBannah | macOS | 20 | 02-03-2012 12:50 AM |
What is Pro Tools Aggregate? | sixstrings22 | macOS | 1 | 10-21-2011 03:00 PM |
