Omni HD ADAT Digital Out Channels 1-8?
Omni HD question.
How do you get the ADAT optical to output channels 1-8? It seems I can only get it to output a pair at a time, but not all 8 channels. I need this in order to run another device (A tascam DS m7.1 monitor controller) that has ADAT in. It appears that the AES/EBU outs are available channels 1-8, but no way to switch that to all ADAT outs. Just AES/EBU. I have read the manual, and I found no answer to this question. |
Re: Omni HD ADAT Digital Out Channels 1-8?
Pro Tools > Hardware Setup >
Select HD Omni from the Peripherals box Then on the Main tab, Under the Output column set Optical Output Format to ADAT
Thanks for the reply. I had already tried that, because it seems the most logical way. Unfortunately I still only get 1 pair of A0AT outs (see image).
The Omni is only an 8 output device. You have used up 6 outputs for monitoring. Your problem isn't the ADAT but that you've used 6 of your channels. You can turn that off by deleting the monitoring setup and then assigning your ADATs starting without outputs 1-2
The monitor path can't be deleted. It is locked.
Thanks for your help! Got it sorted.
How to get 8 channels of XLR Preamps with Omni? | charlesHindigo | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-20-2013 07:09 AM |
HD Omni 24-bit/192kHz? Limits on channels? | 68topls | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-23-2012 07:14 PM |
HD OMNI How many channels of conversion ? | K Roche | Pro Tools TDM Systems (Mac) | 18 | 01-28-2012 06:34 AM |
HD OMNI multible recording of channels? | 24BitMusic | Pro Tools TDM Systems (Mac) | 2 | 01-01-2011 04:05 AM |
Problems with 192 Digital I/O on ADAT channels 9-16 | cd_audio_mix | Pro Tools TDM Systems (Mac) | 2 | 06-21-2007 02:12 PM |
