Upgraded to PT 12.8.3 & Lost EUCON Surfaces
Greetings, everything was fine on my Macbook Pro Mavericks with PT 11.3 and an Artist Control and a Artist Mix. Upgraded to Sierra on the Mac, then upgraded EUCON to 3.7, updated firmware on both control surfaces, and then updated to PT 12.8.3. Now control surfaces no longer connect. In EUCON sys settings, I see both surfaces and my workstation but my workstation won't 'attach' when I try. I have reinstalled EUCON and EUCON workstation with no luck. I added the EUCON to the Mac security accessible settings.
The one other issue is when I set up my router for the two surfaces, my subnet mask is 255.255.255.0 on the router and both surfaces...everything worked great under PT 11.3. I contacted PT Support and they said the subnet mask needs to be 255.255.0.0 but the router does not permit this 266.255.0.0. I am confused and stuck...Anyone have any ideas or possible solutions? Thank you... |
Re: Upgraded to PT 12.8.3 & Lost EUCON Surfaces
Just found this here: http://resources.avid.com/SupportFil...ontrol_3.7.pdf
Important! The EUCON performance improvements introduced in v3.5 make it and all later versions (including v3.7) incompatible with v3.4.x and previous versions of EUCON and EuControl. As a result, the current and future versions must not be run on the same network (subnet) as any 3.4.x or previous EUCON Surface software |
Just downgraded to previous version of EUCON...all appears to be working fine now with PT 12.8.3. Will wait till I get final reply from Avid Support and/or updated EUCON version, past 3.7.
Updated to Eucon 3.6 and lost all my custom Eucon commands | bassmagnetic | Avid S1, S3, Dock and Control App | 0 | 04-18-2017 10:09 AM |
Why is there still no Auto Plugin Focus for Eucon Surfaces? | bobbyguelz | Avid S1, S3, Dock and Control App | 5 | 03-22-2016 04:45 PM |
S3 not showing in Eucon surfaces | Avid2015 | Avid S1, S3, Dock and Control App | 7 | 11-30-2015 12:30 PM |
Multiple Eucon Surfaces with Ableton Live? | djmichaelwenz | Artist Series | 1 | 09-29-2015 10:11 PM |
BUG ?? Eucon 3.1.3 still sees surfaces from disabled Network Interface | bernhard | Artist Series | 0 | 08-20-2014 09:51 AM |
