AJA io XT
Will our PT11HDn rigs look like this in the future?
http://compare.ebay.com/like/2907707..._lwgsi=y&cbt=y Whole system incl. HD-video and audio I/O in one unit? Genlocked HD video and 5.1 audio in one TB box. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: AJA io XT
Hello Frank,
Yes, I had a simular thought.. 5.1 audio and video over one thunderbolt cable. I guess this will be possible in PT 11 now Aja gets supported. |
Re: AJA io XT
Is AJA supported in PT 11 ??? Where did you see that info ??
Re: AJA io XT
Everything from BM and a couple from AJA.
It was mentioned in the video presentation. And here: http://www.aja.com/en/articles/197/
Re: AJA io XT
And on the Avid website: http://avid.force.com/pkb/articles/c...eo-Peripherals
Re: AJA io XT
Thanks guys...This is great news, finally i get to use my Kona 3G and IO XT with PT :)
Re: AJA io XT
And you want to rely on Aja's D/A converters to monitor a 5.1 mix?
I know nothing (either good or bed) about the sound quality of Aja converters. Anyone tried them and compared to at least mBox 3 pro quality?
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
Re: AJA io XT
Edit: Only SDI embedded. So that's that.
Re: AJA io XT
So I picked up an IO XT, and on Monday my aes to sdi embedder will arrive. The plan is to take the AES out of my mic pre into the sdi in on the XT. Then, use the DB 25 to get to my xmon as well as my tv. I can see 16 audio inputs in Protools as well as 16 outs. I will lock it all up to tri level sync. Then, I will test with sync check to see if there is any variance in video playback sync. Also, I am going to patch it to my alt surround input on my xmon to test the audio quality of the DA conversion. Using the same session with both systems (other being a hd native rig with an omni for i/o) chasing LTC, i should be able to switch seamlessly and compare the audio quality. But, if this works well, this would be the box for many many folks. No Avid hardware to buy and with a trashcan or higher end MacBook Pro, a very portable, affordable and powerful rig.
Re: AJA io XT
johnomix.com |
