Old 12-29-2003, 03:43 PM
d_matt d_matt is offline
Default Sliding region contents
Whenever I slide the contents of a region I have to deal with the clicks until I find the right spot. Then I fade it and it's all good. I'm just wondering if there is a workaround for this so that I could slide the regions contents while avoiding clicks. I was hoping I could do the fade first and then slide, but that doesn't work b/c the fade vanishes as soon as you start to slide it.
Is there a better way?
002, PTLE 5.3.2, A7V266-C, XP2100+ (1.7GHz), XP Home
Old 12-29-2003, 04:12 PM
Default Re: Sliding region contents
There is no auto zero crossing detgector in Pro Tools.. and usually a small fade works fine without much work. You can nudge the contents of a region without changing it's start and end time by using the Start modifier with the numeric plug and minus keys. Nudging will remove any fades (as you noticed).
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
PT9 list of contents anywhere? mintyfresh Pro Tools 9 6 11-25-2010 07:10 AM
Duplicate Midi region always sliding off? rdolmat Pro Tools TDM Systems (Mac) 1 05-25-2010 02:06 PM
Structure: missing AIR contents Anangu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-13-2010 10:14 PM
Takes List contents swwazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-10-2004 05:42 PM
International Contents :( Rock_Artist General Discussion 1 08-04-2003 09:15 AM
