Old 06-01-2011, 08:47 PM
DiegoFox DiegoFox is offline
Default Factors contributing to static noise
I am still not sure about the factors contributing to static noise I get while recording acoustic stuff on the Mbox 2. Could these be:
-MbookPro fan (is getting noisy, and kicks in even when CPU is at 5%)
-USB cable
-microphone cables
-mics too close to each other
-wrong PT version (8.0.4, but had these problems with 8.0.3 too)
Old 06-02-2011, 05:52 AM
radkins radkins is offline
Default Re: Factors contributing to static noise
What kind of static? Can you post a sample?
Old 06-02-2011, 08:58 AM
It is like a distant hum in the background. Around 50 Hz, continuous, audible only during resting in music. Can files be posted here ?
Old 06-02-2011, 02:41 PM
The Dougfather The Dougfather is offline
You could do with describing your setup a bit more.
Are you using the USB cable that came with the MBox, they're grey with a little ferrite module on them which stops crosstalk etc.
What about the mic and mic cable, i'm assuming an XLR is being used.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 06-02-2011, 04:57 PM
Yes I am using the USB that came with the Mbox2, and XLR cables I bought at the Guitar center.
Old 06-04-2011, 08:51 AM
Would I maybe be better off with phantom powered mics?
Old 06-05-2011, 01:08 PM
What sore of mic are you using?
Bare in mind dynamic mics with acoustic guitars, vocals etc will need the preamp on an MBox2 to be cranked high, is it possible that the preamp is up full and your hearing noise from it?
A condenser mic would be a good choice for these applications.
iCON Photography
Old 06-05-2011, 03:20 PM
I use SM57. Would I really need a preamp and which?
Are there acceptable mics around which wouldn't need a preamp - maybe these would be a better investment?
Old 06-05-2011, 07:49 PM
SM57's work well with high output sources like snare drums, guitar cabs etc but you need a lot of gain for quiet sources.
There are a lot of great budget mics out there. IMHO you can't really go wrong with Rode. If you want something for vocals and guita then an NT1 would be a good starting point. The NT2 is much nicer but pricier. Rode now have some budget condensers but i cannot comment on them because i have never used them.
iCON Photography
Old 06-05-2011, 08:18 PM
Thx for the opinion.
I'd try NT1 then.
I was happy when recording some fingerpicked jazz solos with a pair of Shures (sound was great, appart from occasional noise). If I get a single NT1, would it be possible to make stereo (i.e. recording to two tracks with one mic - may be a dumb question ).
Static noise DiegoFox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-28-2011 03:00 PM
low static noise in PT 8 fixitinthemix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-30-2010 10:44 AM
Static noise (aka White noise ) During playback. =/ PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-23-2010 04:06 PM
7.3.1 - static noise after using for a while dcrann11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-21-2007 06:11 PM
playback static noise QuikDraw Tips & Tricks 2 02-22-2003 12:42 AM
