#31
Re: 2 midis together?
Hmm, Delta 1010 (PCI/Rack - not the LT version) midi and audio worling great in PT8 and all apps here. I use WinXP and highly suggest driver vers 5.10.00.0051 (or even 5.10.00.5069v3 if need be). Two modded delta 1010's running well. I avoid 6.0.2_5.10.0.5074 (crapola). * do you need the motu? |
#32
I read the small print a bit late on the new Delta Drivers, and not only did they crash the registry but... caused other problems with SPDIF changing sample rates to devices they were connected to...causing a DSP chip disaster. I do need MIDI but am testing out another USB controller. It has a din I/O on rear for keyboards.
DigiTech support. Still the Delta drivers in Device Mgr should allow one to disable midi, yet after doing that XP requires a restart and but then the driver turns midi back on (no MIDI as we know on Delta 66 cards). Is there some trick in Services (management) to disable this MIDI device in the Delta all-in-one driver, but still allow audio? What is turning MIDI back on after a restart, when device mgr has turned Delta MIDI off (disabled). (I am using Motu clockworks to sync PTs le on Mac to the PC). |
A Tale of Two MIDIs... | RegisWhite | Pro Tools 11 | 7 | 09-02-2013 08:37 PM |
