Old 12-28-2018, 09:57 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Default Prevent loss of focus
Is there a way to set the Artist Mix to prevent it from losing focus when you swap out of the main Protools window and have to work in a separate Window or application?
The PT Control app does this also. I would like to prevent this from happening so the faders and PT Control app stay focused on Protools if I have to work on something out side of Protools while Protools is still running.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 12-28-2018, 10:54 PM
BScout BScout is offline
Default Re: Prevent loss of focus
In Eucontrol on your computer, go to the assign page. You'll see Lock to Application at the bottom. Select your program (bring the application to focus on your computer) you want to lock Eucon/Eucontrol to and it should show up next to "Application:" at the top of that Eucontrol tab. Then check the checkbox next to "Lock Application: Entire Surface" and that application name will be listed beside it.
Then all Eucon will be locked to that application even if you go to other applications on the computer. This will be remembered through restarts/closing opening the "locked to" application so if you need it to start moving to other apps, unlock it when you need to.
Old 12-28-2018, 11:01 PM
JCBigler's Avatar
Thanks, I knew it had to be something simple.
Justice C. Bigler
Old 09-14-2021, 02:22 PM
ramonetl ramonetl is offline
This is awesome and so simple! I was in the same position as JC and glad I found this. Peter
loss of a redundant connection loss protools device S3L-X Matysiak.m.d VENUE Live Sound Systems 8 01-25-2017 06:26 AM
PT Crackling/Quality Loss/Eventual loss of sound WhyAvid Pro Tools 12 10 01-10-2016 08:37 PM
DC Offset, what causes, how to prevent rtcstudio Pro Tools TDM Systems (Mac) 7 07-23-2009 07:17 PM
What do i do to prevent my........... melly_j Tips & Tricks 3 05-26-2007 05:04 PM
How do I prevent the window THERE ARE SOME cc1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-21-2006 10:23 PM
