Old 11-25-2019, 07:56 AM
samplaire's Avatar
samplaire samplaire is offline
Default QuickTime Pro best settings for video in PT2019.10 Ultimate
Yes, I still use QT Pro to convert movies to work with in PT. However I'm not 100% sure what I'm doing converting files... I know the prefered format is DNxHD but that's all. There are so many settings in QT that I'm lost... Some of them are obvious but some things I don't understand. Can somebody show me on an example setting window what to set and where? I have the Intensity Pro card and output movies on a TV set via HDMI.
My concern is that I sometimes work with different FPS and I don't understand why the setting is once set to current and in another window it is specidied that it is this or that? Which setting of the DNxHD is right for me? There are plenty of...
What I want to achieve:
- movie to display smoothly on a 1920x1080 TV
- FPS is dependant on the input format (do I have to set it each time or will it be really as in one of this window 'current'?)
Thank you in advance!
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+
Old 11-25-2019, 11:31 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: QuickTime Pro best settings for video in PT2019.10 Ultimate
Those are all the settings I use, except I use DNxHD 36 8-bit.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 11-25-2019, 12:54 PM
samplaire's Avatar
Thanks!
But what is the meaning of those fps settings while choosing 38 8 bit?
Old 11-27-2019, 04:39 AM
samplaire's Avatar
I did a research in the net regarding the settings and I still don't know the details. As Ryan said the DNxHD 36 8bit is the prefered setting. But I also would like to know which of the qt setting for the dimensions, data rate and frame rate will be in the resulting movie?
When you 'export' in QT you get a window, then besides the name you choose 'movie to qt movie' and click 'options', then you can choose size, filter, settings. So first of all I can set size here and then when you click 'settings' you have these 2 parts:
MOTION
where you can set the frame rate
where you can set data rate
COMPRESSOR
where you also set the frame rate.
where you also set data rate
where you set the size
Which size, data rate and which frame rate will be held in the resulting movie?
I'm interested in it because I do work for tv, film, games worldwide so sometimes I need 25 frames, sometimes 24, sometimes 60 and sometimes 23.97...
HTML code is On
Import more than 1 video file with Pro Tools non-Ultimate mixaudio Pro Tools 2019 8 07-15-2019 08:57 AM
EuCon import previous settings to PT2019.5? JeremyG Avid S1, S3, Dock and Control App 2 05-15-2019 01:45 PM
Pro Tools Ultimate I/O, how to remember settings for each session garnoil Post - Surround - Video 6 03-17-2019 03:49 PM
pro tools and video--turning video into a quicktime movie? ncw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-01-2008 12:50 AM
Should I use Quicktime? What settings to use? Sonic Nomad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-06-2007 04:01 AM
