Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 12-15-2015, 05:21 PM
mike841 mike841 is offline
Default Syncing 2 Omni
Hey Gang,
I need to sync (Time Code) 2 Omni together on two different computers for the transfer of audio tracks. Can anyone tell me the best way to do this?
Thanks,
mike
Old 12-16-2015, 08:11 AM
Brandonx1 Brandonx1 is offline
Default Re: Syncing 2 Omni
Connect them on a network with a switch. In the peripherals / Satellites page, Select on a the admin and one as a satellite. That should get you very close to sample accurate sync.
You can also just import the data from on session to another session. I'm not totally sure what you are trying to accomplish here.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 12-16-2015, 12:21 PM
Thanx-a-bunch Brandon,
I know I didn't go into a lot of detail. I need to run the tracks thru outboard gear, so importing won't work. Also, when you say "peripherals page", do you mean in Pro Tools? Not using Pro Tools, using Nuendo.
Do you know if the Avid Sync HD unit will work? I wasn't sure because the Omni does not have smpte or midi ports.
Old 12-16-2015, 03:09 PM
DetroitT's Avatar
DetroitT DetroitT is offline
in Pro Tools
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both
(HFS+)
Pro Tools U-2019.12 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds/upkeep
Old 12-16-2015, 10:30 PM
Sorry. This is a pro tools forum. No clue how to do this in nuendo but they do have a vst link function. Can't you use that?,
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 12-17-2015, 08:22 AM
Also the HD sync will not work outside of pro tools. You need something that works with nuendo.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 12-17-2015, 11:15 AM
I know it's crazy to be posting this on a PT forum but to me it was more of a hardware issue, and all of Avid's other hardware works smoothly with Cubase, so I was wondering if the Sync HD would too.
I prefer Cubase over PT for creation, but their peripherals are clumsy.
Thanks for the help.
-mike
Old 12-21-2015, 08:54 AM
jbrown7282 jbrown7282 is offline
Wouldn't a simple word clock sync cable work???
I don't see why not.... Put the receiving OMNI in slave or External and put the sending Omni in Internal....
Should lock just fine//
Jay
Litehousemuzik
Audio Mixing Services
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 02:00 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 10:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 06:42 AM
Syncing with MTC Chompers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-29-2002 07:36 AM
Syncing with PT 5 LE????? JRogers General Discussion 0 11-22-1999 11:38 AM
