Shift+tab feature how to turn on in 8?
Can't figure out how to turn on shift+tab (select to region next boundary) or apple+shift+tab (select to one before).
It's working on one system but not on another -- seems like a session independent preference. Anyone offer any help to answer my dumb question
_________ 2x2.26 Quad Core/16G Ram - 10.6.3 v1.1 - HD5/192- PE6R4i - PT 8.0.4 - SYNC - C24 |
Re: Shift+tab feature how to turn on in 8?
It's always on, but there are two "modes". If Tab To Transient is on (Command-Option-Tab to engage) then pressing Tab or Option tab will go to or select to the next transient event, but if it's off, then it will go to or select to the next Region boundary. Make sense?
That's where I'm having the problem. I can engage and disengage "tab to transient". I see the icon illuminate blue then not. If I hit Tab and I can tab to regions. But shift+tab doesn't work nor does apple+shift+tab --
of course this was a session built in PT7 that I am now trying to run in 8 -- could be the problem. But like I said this works on another machine that matches this machine almost identically. Same session. Any other thoughts?
I'm still completely baffled as to why we can't have both modes active at the same time.
Why on earth would we want " l " and " ' " on the alpha keyboard to behave the same as the Tab key? Surely it makes more sense to have the Tab key for transient selection, with " l " and " ' " for region selection, giving you both modes without having to click on any icons to switch between the two. |
Have you checked your system prefs and turned off any other system keyboard shortcuts? |
Timothy |
Did they change this in 8?
It's actually Option-Shift-Tab in 7... |
alt=option
How to turn Soft Key on AC into SHIFT key? | digidesigner | Artist Series | 0 | 03-11-2013 06:50 AM |
Anyway to turn off shift lock | Brandonx1 | Artist Series | 9 | 08-01-2012 01:54 PM |
Help me turn this "feature" off | davegibbon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-29-2007 12:01 PM |
Help me turn this "feature" off | davegibbon | MIDI | 1 | 07-29-2007 04:04 AM |
New Feature of 6.7??? Can I turn it off? | Chris Cavell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-06-2004 11:16 PM |
