Old 05-06-2010, 06:09 AM
ArcadiaDivine ArcadiaDivine is offline
Default Curious concern
I don't know how to explain this so bare with me.
Whenever I use any plug-in and begin editing something, it always erases whatever's above that line. Is this fixed through a setting?
If it helps I'm using pro tools 8 with the M-Box 2 mini.
Old 05-06-2010, 06:32 AM
BradLyons BradLyons is offline
Default Re: Curious concern
What line? Could you please try to explain more in-depth? Thanks!
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 05-06-2010, 07:54 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Originally Posted by ArcadiaDivine View Post
If it helps
Not @ all
I'm with Thee Mad Brad.. I hav no clue what ur talkin about so u may wanna show a screenshot or 2...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 05-06-2010, 12:26 PM
netnoggin netnoggin is offline
That used to be my go-to pickup line with the ladies.
NN, aka Hobonoggin
H.I.T. Program graduate (Hobo Internship Training)
Old 05-06-2010, 12:31 PM
mano111 mano111 is offline
I'm betting it didn't work, or that you married the one that fell for it.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 05-06-2010, 01:45 PM
It usually ended with me being the only one bare and thrown out of the club on the street.
NN, aka Hobonoggin
Old 05-06-2010, 02:22 PM
That was YOU I still have nightmares........
Old 05-06-2010, 02:35 PM
sorry about that...I forgot to say it only happens when I use the copy and paste trick
This is before I pasted
http://img88.imageshack.us/i/beforek.jpg/
This is Afterwards
http://img191.imageshack.us/i/afterqi.jpg/
I hope that helps
Old 05-06-2010, 04:05 PM
Whether you're using a plugin or not, it just looks like you've copied and pasted a section into an inappropriate location.
(404)844-9758
blyons@gcpro.com
Old 05-06-2010, 08:01 PM
Concerttom Concerttom is offline
When you're on the Notes Pane in the MIDI editor window, you can right-click and get different editing options. If you select "merge," it'll put in the notes you're moving and leave the previously written ones there as well. That might be what you need to do.
From the PT Reference Guide (in MIDI editing chapter):
Merge
The Merge command pastes the clipboard to the
current Edit selection or at the current Edit cursor
location and merges the pasted data with
any MIDI notes already present at the same location.
MacBook Pro, OS 10.6.2, Intel Core 2 Duo, 2.6 GHz, 4 GB Memory, 003 Factory, PT LE 8.0.3, G-Tech G DRIVE Q 1TB HD
'Wave of the future, Dude. One hundred percent electronic.' -- J. Treehorn
iLok question / Concern. TruestPain Getting Started 4 05-22-2013 08:07 PM
Installing Pro Tools 9 on 10.6.8 concern rexpost macOS 4 03-18-2013 01:09 PM
Mbox 3 Pro concern- defective? david cos macOS 0 09-04-2011 05:09 PM
Plugin Concern Stewy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-26-2009 09:40 PM
to whom it may concern...... bi0force1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 07-20-2002 01:01 AM
