Old 08-15-2008, 05:40 AM
Luke K Luke K is offline
Default Drum Editing
I have just started my first major drum editing job (for a self produced album) Im completely new to the idea of drum editing and would love any tips tricks people use.
So far all i really do is align kick and snares with the click..and put crossfades in to smooth them over. What other tools can i use? are there any tools that lengthen a drums hit? or shorten?
Also as far as spill goes is it beneficial to edit out all the spills manually or use strip silence. For some tracks i can use a gate...but for others i need to isolate the tom hit and use gain to get a decent level.
Any tricks/tools in this area would be greatly appreciated
Thanks,
Luke K
Old 08-15-2008, 06:03 AM
mountainman mountainman is offline
Default DigiDesign TV
DigiDesign TV have some good tricks on drumediting.
It's under the section of ProTools 7.4 (chapter 6,7 and 8).
God luck!
Old 08-15-2008, 06:06 AM
Stig Eliassen's Avatar
Default
Make an edit group and edit all drum tracks together to avoid phase issues. The only tracks I sometimes edit out spill from are the toms. I'm not too fond of how the tom mics affects the snare sound, so I use gates or edit the tom regions manually with tab to transient.
The transient designer from Sonalksis is capable of changing the attack, length and timbre of drums. It's included with Superior 2.0 from Toontrack. Don't know if it's available separately.
Old 08-15-2008, 06:07 AM
Default
God luck!
Wow never heard of didgidesign tv before..looks great...thanks!
Old 08-15-2008, 06:08 AM
Default
Yeah i am editing drums in group apart from when it comes to toms and their gain issues.
Old 08-15-2008, 07:03 AM
dougied dougied is offline
Default
I use gates on on all toms, snares, and a little on the kicks. Compression, EQ, Reverb everything etc... pretty much on all drum tracks.
Trust your ears!
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 08-15-2008, 07:08 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default
The way I do it is edit all the spills manually out the toms that way I can really make the toms sing...I carry them a little farther than the next hit & put slight fades on them...I mix mostly gospel records in that manner as well as some pop records...Still, as someone stated, its just whateva sounds best to u...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-15-2008, 09:55 PM
Yawn Yawn is offline
Default
Which version of PT are you using?
If you're on 7.4, then you can use Elastic Time, which is freaking amazing! There are excellent tutorials on Digidesign's website for using it. Elastic Time has more than halved my drum editing time-debt in PTLE, and it sounds pretty damn good, especially considering the amount of adjustment that you can do with it. Take a day and learn it! It will save you days of work in the future, I promise.
Otherwise, group all of the drum tracks so that you edit them all together to maintain phase coherency between mics, as already stated. PT's native gate plug-in is nice for suppressing tom-tom ring. Use the "range" and "ratio" knobs to taste, as sometimes I find that completely eliminating that bleed (via strip silence or the like) kind of melts the "glue" in a whole kit sound. Unless, of course, you're going for that close-mic, separated sound.
Old 08-16-2008, 01:29 AM
Default
Im using 7.3 I didnt think to upgrade as it only seemed like 7.4 had good video upgrades. So its worth it for drum editing? and its just a download update right?
Drum editing lag in Pro Tools LE muscanto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-04-2008 10:30 AM
drum editing wishesonaplane General Discussion 2 09-16-2006 05:58 PM
Drum Editing Plastik909 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-27-2004 03:31 PM
Drum editing techiques? silence_of_stone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 05-25-2003 08:03 PM
Tom Drum editing seeds Tips & Tricks 10 06-17-2002 10:56 AM
