Old 09-10-2007, 08:51 PM
dstagl dstagl is offline
Default v2.6 routing question
Is it safe to assume that if you route a variable group to the main busses, delay compensation will work if it's turned on?
Dave
http://www.goingto11.com
Old 09-11-2007, 12:31 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: v2.6 routing question
Hi Dave,
Yes, double bussing scenarios involving Var Groups are delay compensated, just as with the mono and stereo groups.
Sheldon
Old 09-11-2007, 12:44 PM
Scott Fahy Scott Fahy is offline
Default Re: v2.6 routing question --Release Date?
Sheldon is there a release date on 2.6
Scott
Old 09-11-2007, 03:54 PM
Not soon enough...
I think a better question is, why can't we ever just download these things instead of waiting for an upgrade package?
Dave
Old 09-11-2007, 04:06 PM
Yea what Dave said Wait I did download the last update???? I am confoozed
Old 09-11-2007, 10:01 PM
The tweaks are typically downloads, but the newer versions ala v2.0 and 2.5 were not downloadable.
Dave
Old 09-11-2007, 11:30 PM
Ah tis true-- it was the update to 2.5.3 that was downloaded. After updating so many things on all the computers around here it's hard to remember.
Old 09-12-2007, 08:19 PM
Hey Dave,
The short answer is that each major release also contains an updated version of the underlying operating system, in addition to the D-Show software. Under the terms of the software licensing agreement we're obligated to distribute the OS via CD only. I realize it's not always ideal, but the upgrade kits can typically be expedited w/ overnight shipping if needed.
Minor "dot" releases that only affect the D-Show software will always be downloadable whenever possible.
Sheldon
Old 09-13-2007, 09:20 AM
That makes sense. So I guess I need to get my plugin installers ready to reinstall.
Dave
Old 09-13-2007, 11:59 PM
Hi Dave,
If you do an update instead of a full restore the plug-ins can be installed directly from the "Previous Installs" option on the left hand list on the Options>Plug-Ins page.
The ECx software will need to be re-installed, but we've made that easier too. Once you've done the update simply remove all USB keys and then click the UPDATE button on the Options>System page. This should then find and re-install the ECx host software from the local hard drive.
Sheldon
Routing question ? Raoul23 Tips & Tricks 15 03-21-2013 03:39 AM
Can you help me with a routing/pre amp question? stickboymusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-19-2010 11:39 AM
Routing Question DLinares Virtual Instruments 2 03-21-2006 09:26 AM
Another Routing Question! EricLiebman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-17-2002 05:42 AM
To bus or not to bus.....(routing question) maxcap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-28-2001 01:13 AM
