Old 06-30-2007, 10:26 PM
williamsongs williamsongs is offline
Default PCI cards for 882/20
I have been using a legacy system for years, and recently got a new PC. The new enclosure won't allow the PCI card to be installed. There is just not enough room in the case for the card! Are there any other PCI card options to interface with the 882/20 interface besides the Disk I/O, the DSP Farm, or the Project Disk card? I don't want to buy a Magma case. I'm using the 882 as an extra I/O with an ASIO driver in a non-protools DAW.
Any ideas or custom PCI cards out there?
Old 06-30-2007, 11:58 PM
Pepo Pepo is offline
Default Re: PCI cards for 882/20
Any pro tools pci card will take an 882, exept for the hd cards and cards that belong to LE systems.
If it is windows, then you need any card that is windows compatible. And it will also depend on your operating system version.
Maybe a d24 or mix core if what you sould be after.
Pepo
Old 07-01-2007, 06:31 AM
Windows XP SP2. The DSP Farm I have can't mount in the PC I bought. It's too long. I know the MIX cards are the same size, so that won't fit either. Are the d24 cards smaller? Like the old Session I/O ISA cards? If not, it looks like the Magma chassis is the only way around this problem.
Old 07-02-2007, 12:05 PM
I would replace the cpu cabinet, should be much cheaper. There was a project studio card (not project pci) that was shorter. You can check the digidesign propix page to see all cards.
Pepo
Old 07-08-2007, 04:24 PM
ppuskari2 ppuskari2 is offline
Yes, the D24 cards I believe are 7" pci cards.. Or at least if I remember correctly they are.
Good luck!
ppuskari2
HTML code is On
Accel Cards next to other PCIe Audio Cards in the same Mac Pro for PT 10+11? relaxo Pro Tools 11 11 05-13-2018 03:01 PM
Are all pcie cord cards, accel cards? fourthtunz Pro Tools TDM Systems (Mac) 2 11-20-2011 09:41 AM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 03:39 PM
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in phatbeatstudio Pro Tools TDM Systems (Mac) 6 10-16-2011 12:35 AM
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! A Spooner Tips & Tricks 6 07-08-2009 07:55 PM
