Old 10-09-2005, 03:02 PM
JonnyGinese JonnyGinese is offline
Default ProjectMix i/o vs Command 8 for acontrol surface
hey,
I'm looking around for a control surface and i was wondering if the ProjectMix i/o will work just as well as the Command 8... and since the ProjectMix i/o has the acctual inputs part of it I could use it for more then just a control surface if i wanted to... So I'm just wondering if I'm going to spend 1000 or so on a command 8... would be be getting just as good integration with the ProjectMix i/o? becasue if so it seems like that woudl be the better buy.
Input please.
Jonny
-AIM: RS Recordings -Skype: RSRecords
| Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r |
Studio Site: Red Sneaker Records
Old 10-10-2005, 03:32 AM
bb_aus bb_aus is offline
Default Re: ProjectMix i/o vs Command 8 for acontrol surface
i dont think the project mix is shipping yet
Old 10-10-2005, 07:03 AM
whitecat whitecat is offline
Nowhere in the specs does it mention LE compatibility either, only M-Powered is listed... unless I've missed something.
Old 10-10-2005, 07:11 AM
AM STUDIOS AM STUDIOS is offline
If you can put in HUI mode it will work in PTLE but if you cant it wont work.
Old 10-10-2005, 07:22 AM
under compatability
Pro Tools M-Powered 7 or greater
All Pro Tools systems (MIDI control only)
so it should work, and it seems it supports HUI aswell. the question is how well it works, not sure if the master fader would work in PT.
PT9 Command 8 with another control surface finkbmx ProControl, Control|24, Command|8 22 11-25-2015 01:35 AM
Projectmix or Command 8 GBProSound Pro Tools M-Powered (Win) 4 12-14-2007 04:27 PM
ProjectMix I\O control surface not working in 7.1 TBF Entertainment Pro Tools M-Powered (Win) 7 06-21-2006 10:05 PM
Difference between Command 8 and ProjectMix IO??? gar_lei ProControl, Control|24, Command|8 9 02-28-2006 05:32 PM
New command 8 control surface blue demon General Discussion 13 04-07-2004 10:03 PM
