Old 12-29-2004, 06:50 AM
Edson Edson is offline
Default Oxygen 8 M-Audio
Ok..I have a Oxygen 8 M-Audio midi keyboard. What is the correct way to connect it so Pro Tools recogonizes it. Right now I simply have a USB cable going into the computer which powers the keyboard, will that be enough or do i need to connect a Midi to USB cable??
Thanks, this really has been giving me problems....
www.myspace.com/kidboy
Old 12-29-2004, 03:22 PM
neatguys neatguys is offline
Default Re: Oxygen 8 M-Audio
Thats all you need
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Old 12-29-2004, 04:34 PM
Touch Sound Touch Sound is offline
You should connect MIDI cable from the keyboard to your 002
Tony Jacobsen
Touch Sound
www.touchsound.com
"Creating a World of Sound You Can Feel"
Old 12-30-2004, 09:53 AM
da BaSsTaRd! da BaSsTaRd! is offline
no - use the usb. for some reason, these m-audio usb keyboards defeat the "PT steals midi ports" phonomenon. this will come in handy if you're rewiring anything into PT.
i love my apple iPhone!
Old 12-30-2004, 11:45 AM
blizzard blizzard is offline
I just got the oxygen8 and reason and I am having usb problems here
Curious as to what you mean by "PT steals midi ports"?
cheers
blizzard
DAW - Asus P9X79 / 32GB / i7-4820K / WIN7 PRO / VEPRO 5
PT 11.3.0 / Blacklion 003R / Microclock
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 12.4
Old 12-30-2004, 12:55 PM
i just checked out your other thread. looks like there's a 50/50 chance that it could be a hardware problem to me. you could format your system drive and reinstall windows. if that doesn't work, then its most likely a hardware problem.
PT and midi hardware are not good buddies. when you launch PT, PT will attempt to acquire exclusive use of and lock out all physical midi ports. what this means is that you can't use any of those midi ports with another program (such as reason) as long as PT has exclusive use of them. that really sucks because i like to sequence reason in the reason sequencer and when it's rewired to PT, reason can't get access to any midi ports to sequence with.
however, for some reason the m-audio usb midi ports (including the usb keyboards) get around this. i can use my radium 61 keyboard for both PT and reason when they're rewired together.
Old 12-30-2004, 01:07 PM
I think you're on the right track about a hardware problem. It seems like something might have gone awry inside the box. I just have to backup everything I need then I will format my system drive and reinstall XP. Fingers crossed that it works.
I'm glad to hear that the m-audio stuff seems to work around PT's greediness because I too want to work within Reason while it is rewired to PT.
thanks
blizzard
M-Audio Oxygen?? ThunderKyss MIDI 3 12-06-2013 11:52 AM
M-Audio Oxygen 25 Councillor Getting Started 11 11-05-2013 12:13 PM
M audio oxygen 3rd gen RettRobinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2010 10:57 AM
M audio oxygen 3rd gen RettRobinson MIDI 0 01-25-2010 04:32 PM
just got the M-Audio oxygen 49 v2 jonslaten MIDI 6 12-28-2009 05:08 PM
