Old 03-11-2009, 12:31 PM
Bryan Talbot Bryan Talbot is offline
Default AutoTune berserk after changing session start time
PT 7.4.2.
After doing some moderate tuning in graphic mode. I did a session start time change, maintaining region timecode position.
I'm talking WACKED...weird, incorrectly pitched shifts...just bizarre. I had to go back to a previous save, record the tuned track and import it into a newer saved session.
Anyone else?
Old 03-11-2009, 02:17 PM
Rail Jon Rogut Rail Jon Rogut is offline
Default Re: AutoTune berserk after changing session start time
AT keeps track of the pitch changes from the top of the session.. by changing it, you affect AT's offset.
Did you also change the memory allocation setting inside AT to cover the longer timeline?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-12-2009, 12:57 PM
Rail
Thanks, it did seem like a timeline issue...I'll follow your suggestion.
Old 03-12-2009, 08:01 PM
Mark Dann Mark Dann is offline
Once you use graphic mode in AT (or Waves Tune), you cannot make edits that change the timeline without having to redo your pitch corrections from that point in the timeline thru the end of the song. That' just the way it is.
Changing Session Start time in PT 10 billborg Pro Tools 10 0 11-12-2011 09:31 AM
Changing session start time? Krizaps Pro Tools M-Powered (Mac) 2 04-29-2011 06:24 PM
Changing Session Key with AutoTune 5 RichrdC Pro Tools M-Powered (Win) 2 02-05-2010 09:28 PM
Maintain timecode when changing session start time Jake Jackson Pro Tools TDM Systems (Mac) 9 05-23-2005 09:43 AM
changing session start time? anders Tips & Tricks 5 03-13-2001 01:14 AM
