Old 03-25-2023, 09:25 PM
fiddlefro fiddlefro is offline
Default Has Sibelius REWIRE been disabled in 2023.3?
Hi there, I can't seem to find anything about this in the release notes, but it seems that the REWIRE plugin 'Sibelius' is no longer functioning in ProTools Ultimate 2023.3
Is this intentional (is it being phased out?) or is it something that's still on the list to fix?
If it has been discontinued intentionally, is there another way to host the audio from Sibelius in ProTools and synchronize the transport like the REWIRE plug does?
Thanks!
Old 03-25-2023, 09:37 PM
BScout BScout is offline
Default Re: Has Sibelius REWIRE been disabled in 2023.3?
Rewire has been ended by Propellerhead (developer of the protocol.) It is being terminated in use by everyone. Reason (Propellerhead) made this announcement a few years back:
Reason Studios has announced that they will discontinue the Rewire protocol at the end of 2020.
Avid (and everyone else) have no choice but to find new solutions. And they aren't available yet for many software packages.
Old 03-25-2023, 09:59 PM
nednednerb's Avatar
nednednerb nednednerb is offline
And I saw this (screenshot).
Maybe it will work for now under Rosetta with your existing install? I do not use Rewire or Silicon iMac so cannot test. I noticed this glancing earlier, and reminded myself reading this post.
Forward though, the above stands. It is no longer actively supported
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 03-25-2023, 10:03 PM
Sardi Sardi is offline
As BScout mentioned, ReWire has been deprecated for several years now.
Also, it is in the release notes.
https://avid.secure.force.com/pkb/ar...-Release-Notes
EDIT: Beaten by a couple of mins. =P
Old 03-26-2023, 04:38 PM
Oops! Missed that in the notes. I thought I had looked!
Anyone have any hot tips on another way to sync Sibelius (and other music applications) with ProTools? I don't care as much about the audio routing, but transport sync would be so useful!
Old 03-26-2023, 06:16 PM
lego lego is offline
Aren't your apps showing up in the Insert -> Instrument menu?
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley
Old 03-26-2023, 06:23 PM
Those apps in the instrument menu are REWIRE plugins. They are no longer present in the Apple Silicon Native version of ProTools.
Turns out that, for the moment, running PT using Rosetta allows me to use Rewire again (excellent suggestion above, by the way!) but I’m concerned that AVID removed useful functionality without providing an alternative. Really any way to sync MTC between apps would be fine, which PT does but sadly Sibelius can’t do.
Old 03-26-2023, 06:24 PM
Good thought! Running PT in Rosetta solved this. For the moment, and for my purposes, I can keep switching Rosetta on and off when I need this functionality.
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
protools sibelius rewire jonbirdsong Pro Tools 12 2 12-27-2021 12:52 PM
Export->Sibelius is disabled. why? huzzam Pro Tools 12 9 10-21-2017 11:26 AM
Using Rewire with Sibelius 8 TZP Pro Tools 11 1 04-29-2016 09:29 PM
Sibelius Rewire Pro Tools 11 mmcl Pro Tools 11 2 08-14-2014 10:48 PM
