Old 01-24-2022, 11:10 AM
MusicRAV MusicRAV is offline
Default HD I/O Expansion Port Cable Length
Does anyone know the absolute limit for the length of the DigiLink Mini cable that runs from the Expansion Port of one HD I/O to the Primary Port of a second HD I/O?
There are many references to using the included 18" cable for this purpose, but that would be a very restrictive limit that would pretty much force the second HD I/O to be stacked with the first.
What I would like to is have one HD I/O in each of four equipment racks (four total from each HDX card).
Old 01-24-2022, 01:13 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: HD I/O Expansion Port Cable Length
They make 12' cables. Should be enough?
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 01-24-2022, 01:16 PM
BScout BScout is offline
What sample rate? (You can't run high sample rates on the long cables whether primary or expansion)
max supported length on ipass cable for magma expansion chassis EB4 EB7 gandlz Pro Tools TDM Systems (Win) 2 05-03-2020 04:11 PM
Holy Grail Y Cable Pinouts - HD Legacy Port to Dual Mix Computer Port AMZavareei Pro Tools TDM Systems (Mac) 1 03-11-2012 08:09 AM
Max length for the PCI I/O Expansion Cable on Mix3 SHIRK Pro Tools TDM Systems (Mac) 1 08-19-2003 12:49 PM
Cable length for 001 Patriq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-31-2003 06:07 PM
Cable length from cpu to 888 Rob Macomber Pro Tools TDM Systems (Mac) 3 11-08-2000 08:03 AM
