*NEWBIE* Static White Noise Pro Tools 8 Digi 003
i conected my Digi 003 and M-Audio Octane together via a Optical cable. Created a session, both 003 and octane are at 48hz.
I created a track and selected analog input 1 and the mic connectedit works perfect! THEN I SELECT ADAT 1 and i get a really load static white noise that peaks my meter! if i speak into the mic you can bearly hear my voice over the static? Can anyone PLEASE help me! thank you... I'M RUNNING: DIGI-003 M-Audio Octane Pro-Tools LE 8.05 ***Dell - Inspiron*** Processor Brand Intel® Processor Intel® 2nd Generation Core™ i3 Processor Speed 3.3GHz Cache Memory 3MB System Memory (RAM) 6GB Hard Drive Type SATA (7200 rpm) Hard Drive Size 1TB Graphics Intel® HD Graphics 2000 Operating System Windows 7 Home Premium System Version 64-bit |
Re: *NEWBIE* Static White Noise Pro Tools 8 Digi 003
Go to setup>Hardware and select your clock source to ADAT. When connecting digital signals, there must be one master clock(or you get just what you are getting)
Thanks albee1952, I tried that and it is still giving me the static..any other suggestions? Thanks again!
Check all your connections. Make sure your mic is using a straight xlr to xlr cable. Create a new session and start fresh(in case the session with the noise is corrupted).
I checked all the connections(optical,FireWire,xlr) and they seem to be fine. I also created several new sessions with different sample and bit rates but i still get the static.. When I record with Analog 1-8 it works fine, it's when I use Adat 1-8 that gives me the static almost pink noise kinda sound.. Could my optical cable be bad? I was using it on a digi 001 and the same Octane and it worked with no problems...I don't know what else it could be!! Haha , thanks again!!"
Thats the thing, the clock does stay on Adat, which makes me doubt the cable is bad...I tried 44.1 and 48 and theres no difference.. I might switch out the optical anyways..correct me if I'm wrong but I think I read that I have to pay to get support from Avid??
Time for more info then. Start with a Sandra report as described in this thread: Help us Help You - READ THIS Before Posting!
Then be aware that, in general, Dell's are a crapshoot for comparability, integrated graphics(which you have) is often a show stopper with Pro Tools, and you need a separate 7200 rpm hard drive for recording(not your C: drive and not a partition of it).
Sandra Report :
SiSoftware Sandra ----------------------------------------------------- ID Host Name : Sergio Mendoza-PC Workgroup : WORKGROUP Computer Model : Dell Inspiron 620 To be filled by O.E.M. Serial Number : 3SF7MS1 Chassis : Dell Desktop Mainboard : Dell 0GDG8Y Serial Number : ..CN7016322D0460. BIOS : Dell A04 11/21/2011 Total Memory : 5.92GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz (2C 4T 3.3GHz, 3.3GHz IMC, 2x 256kB L2, 3MB L3) Chipset Memory Controller : Dell Core (Sandy Bridge) DRAM Controller 100MHz, 2x 3GB DIMM DDR3 1.33GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Hynix (Hyundai) HMT351U6CFR8C-H9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston K1N7HK-ELC 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : Intel(R) HD Graphics Family (6 SM4.1 850MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Video Adapter : Intel(R) HD Graphics Family (6 SM4.1 850MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Graphics Processor Compute Shader Processor : Intel(R) HD Graphics Family (6SP 850MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Storage Devices Seagate ST31000524AS (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:) Generic- Multi-Card (USB2) : N/A (E:) TSSTcorp DVD+/-RW SH-216BB (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices RECOVERY : 15GB (NTFS) OS (C:) : 917GB (NTFS) @ Seagate ST31000524AS (1TB, SATA600, 3.5", 7200rpm) Removable Drive (E:) : N/A @ Generic- Multi-Card (USB2) Optical Drive (D:) : N/A @ TSSTcorp DVD+/-RW SH-216BB (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell H61 LPC Controller LPC Legacy Controller 1 : SMSC SCH5514D-NS Audio Device : Dell Cougar Point High Definition Audio Controller Disk Controller : Dell Cougar Point 4 port SATA IDE Controller Disk Controller : Dell Cougar Point 2 port SATA IDE Controller USB Controller 1 : Dell Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Dell Cougar Point USB Enhanced Host Controller #1 FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Dell Wireless 1502 802.11b/g/n (802.11n (HT), 150Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
I see a few red flags here:
Integrated graphics-often a show stopper with Pro Tools mis-matched RAM sticks-I always use matched RAM I only see a single hard drive-you need to record to a separate 7200 rpm drive and NOT firewire for a Windows 7 system Wifi(802.11) needs to be disabled when running Pro Tools Since its a laptop, there's nothing you can do about the graphics, other than try fixing the other issues and keep fingers crossed. You should start with a good USB2 external recording drive(buy a generic case and pop in a WD Caviar BLACK drive) and turn OFF the wifi and see what happens. If its still fubar, try pulling the 2GB stick of RAM. If that seems to help, replace it with a matching 4GB stick from Hynix. Also, since you're new to this, I would review all the system tweaks too
static white noise | Rawer | macOS | 15 | 03-31-2013 01:16 PM |
static white noise solution | craigyj | Pro Tools SE and Essential (Win) | 2 | 02-21-2011 12:06 PM |
Static noise (aka White noise ) During playback. =/ | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-23-2010 04:06 PM |
White Noise (static) on Digi 002 Mic inputs 3 & 4 *DELETED* | elankf1 | Pro Tools M-Powered (Mac) | 1 | 11-01-2006 10:16 AM |
Static/White Noise | Neodustin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-06-2006 04:21 PM |
