Fades corrupted when copying session from drive to drive?
I'm working on a session today was saved down from Pro Tools 7.4 to 6.x so I could mix and edit on my Mix system. The session saved down fine and I opened it up in Pro Tools 6.4. There are over 1,000 fades. They all sounded good. Then I made a copy of the whole session, data and fade files to another of my drives to do the work. When I opened up the session over there I got the usual "disk allocation" messages, and the Task window to locate the audio and fade files, which I set to "automatic". It found them all no problem. But when I started working in the session I got suspicious because every fade sounded like crap, with pops and clicks that should not have been there. If I deleted out the crossfade and rebuilt it with Ctrl-F in exactly the same spot it sounded fine. So something about opening up the session and locating the fades on the new drive totally screwed them all up. I tried setting up the session again this time clicking on the "regenerate fades" box, but it didn't make any difference. The session is configured as .WAV, and I'm running a G4 Tower / OS 10.3.9. Would that be it...? If I do a "Save Session Copy In..." from the first drive to the second, and choose to create a copy of all the audio files and fade files, that works fine... Shouldn't I be able to just copy everything to another drive, open the session and have it find all the fade files - and have them not be messed up...? Thanks! - Steve |
Re: Fades corrupted when copying session from drive to drive?
why even bother copying any fade files ?
just skip all the fades and re-calculate them when you open the session
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
+1 forget the fades.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
problems after copying session to new hard drive | anklebiter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-22-2009 09:10 PM |
Disc Allocation when transferring session from drive to drive... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-17-2003 03:37 PM |
external drive was corrupt...lost 4 sessions after copying them to drive. help! | djc8902 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-12-2003 01:27 PM |
corrupted audio suite files/drive | stratosphere | Pro Tools TDM Systems (Mac) | 0 | 03-04-2002 04:49 PM |
copying a session to a new drive... | maatmu | Pro Tools TDM Systems (Mac) | 10 | 08-30-2000 07:16 PM |
