Another Licensing Question
Pro Tool Express (10.3.4) was bundled with my M-Audio M-Track hardware. I seems somewhat limited in what MIDI hardware it will interface to: not sure how correct this is as I am just starting out and I don't have any MIDI hardware to try this out, nor do I want to buy any in case I then need to shell out on new software too.
So, can I connect and sample from MIDI hardware into the version of Pro Tools Express I have or do I need a different version. I've read somewhere that this bundled version can't be upgraded either so I'll have to buy a full version. Is this true? $$$ Thanks. |
Re: Another Licensing Question
Hi JamesJL,
Unfortunately, Pro tools Express Akai Edition is just compatible with M-Audio Hardware and will not work with any other hardware. And I'm sorry tell you that there is no upgrade available from Pro tools Express Akai Edition to the latest version of Pro tools. Best Regards, YD |
Thank you for your reply. Given your response are you able to confirm if the m-audio hardware it's compatible with any of the full versions of Pro Tools?
We don't have the list of the compatible third party hardware with our Pro tools 12. I highly suggest to contact M-Audio to check if its going to work with our Pro Tools 12.
Best Regards, YD |
PT licensing confusion/question | Bender412 | Pro Tools 9 | 21 | 02-04-2011 10:55 AM |
question about ilok licensing... | thenassaproject | Virtual Instruments | 6 | 12-24-2010 01:54 PM |
Licensing question | pappatoad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-28-2010 05:09 PM |
Licensing question... | matts9383 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-28-2004 03:10 PM |
